Want a clutch other than the crap ACT?? well look no further!
Old Sep 14, 2003
PdchasinR6's Avatar
PdchasinR6 is an unknown quantity at this point
hey guys, i have the ACT xtreme clutch and i frankly hate it. when my car was up and running i would find that it would heat up very quickly and a fwe times i got stuck in traffic and it actually got to the point where it was slipping just b/c i was in stop and go traffic! The past few nites i've been investigating about clutches since no one really else has offered a clutch for our D17's yet and the answer was closer than u think it would be.
D16: has a 212mm disk with a spline shaft of 20-7/8.
D17: has a 212mm disk with a 20-7/8 spline shaft...BINGO!
it sounds really dumb but ANY D15 or D16 clutch will bolt directly onto our cars without a problem. I called Clutchmasters on friday to confirm it and after they looked up the specs they confirmed that the clutches are interchangeable......Monday im off to find a good deal on a Clutchmasters Stage 3 w/ Carbon/Kevlar disk which my friend has on his supercharged Si....after seeing how much abuse he puts it through and how well it holds up i would reccommend that clutch to anyone.
Old Sep 14, 2003
Jodster's Avatar
Post Whore General
Old news man. On my old 01 EX coupe I installed an ACT stage 2 clutch for a 92 civic VX 1.5L and I had no problems what so ever even in stop and go traffic.
Old Sep 14, 2003
opto_isolator's Avatar
I didn't even know that there was a problem with the ACT clutch.....I don't see many posts about it being crap....
Old Sep 14, 2003
PdchasinR6's Avatar
twice at the track my clutch got heated up enough to start to slip and i had to wait over an hour before i was able to make another run down the track. i cant wait til i dont have to deal with anymore.
Old Sep 15, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
did you break it in?
if not you probably have hot spots on it.
Old Sep 15, 2003
MadWheel's Avatar
Premium Boosted Member
Yeah from what I hear, if you don't break it in properly, it will have this "resin" and result ultimately in premature wear. That may have been the problem man, ACT is a very reputable company.
Old Sep 15, 2003
PdchasinR6's Avatar
at the time of the clutch install my motor only had 600miles on it so i had no choice to but break the clutch in properly b/c i was still breaking my motor in....i gave the clutch a good 450miles to break in which is 420miles more than i gave my centerforce in my DSM. the break-in doesnt have anything to do with it in my case. i just believe that i either got a bad clutch disk from them or it was poorly designed for our cars...either way i still think people should stay away from the ACT clutches for our cars. i have had an ACT in my DSM and i know they are a good company. in both cases the clutch didnt last very long for me however so this was their final chance for me.
Old Sep 15, 2003
MadWheel's Avatar
Also, I aim to buy the center force and according to your post, you were pleased with it installed on your dsm, so i look foward to that.
Old Sep 15, 2003
blckpwdr's Avatar
i have a clutchmasters stage 2. it grabs harder than my friends centerforce in his integ.
Old Sep 15, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
whats the best clutch for a turbo? like what stage ?
Old Sep 15, 2003
PdchasinR6's Avatar
if you want to spend the 400 bucks then the Clutchmasters Stage 3 pressure plate w/ the carbon-kevlar disk is the best in my mind. My friends Si takes a beating with it and after seeing that i have COMPLETE faith that it will be perfect for my car as well...Clutchmasters told me the clutch should support anything under 475 ft-lbs of torque which i dont think ill ever see.
Old Sep 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
you DEF did NOT break ur clutch in right.. or u seriously abuse your car.... cause i BEAT THE HELL OUT OF MY CAR.... i blew a hole threw my block so that should give u an idea of how bad... now i have a new engine, turbo, and act extreme clutch kit.... that never happened to me, not even close... its def a great clutch... its stiff not hard and very responsive .
Old Sep 15, 2003
PdchasinR6's Avatar
OsOBooSTeD....you blowing a hole in your block doesnt have anything to do with how badly you beat on a car. that most likely just means your stupid and u thought u were "special" and cranked the boost too high or u missed a gear popped it. I used to own a 01' EX before i bought my 2003 and i had gone through 3 motors and 2 tranny's but so i know perfectly well what the car can and CANT take as well as how to abuse a car. I've abused things in ways that you cant probably imagine as well as probably done plenty more things than you have in a car. You have to also consider that i live in PA where there is plenty of hills and after sitting in traffic and having to slip my clutch for 20 minutes i would have to drive out of boost for 30-45minutes b/c that ACT would slip if i would build boost....never in any of my previous cars have i seen something like that. I need something that can be driven an hour to the track and hold up for 15-25 passes and not start burning up like that clutch did.
Old Sep 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
uhm just to FYI... i blew the engine WAY before i had a turbo... thanks. yea.
and dude.. what u need is to learn how to drive.. not a car that can handle that type of abuse..
Old Sep 15, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
welll.... this is my 2nbd car with ACT clutch/// NEVER hjad a problem.. maybe you just bought one too weak for your driving style.. i have a 6puck with the 11lb flywheel... NICE setup... i recomend it...
Old Sep 16, 2003
PdchasinR6's Avatar
OsOBooSTeD...why dont u come down here and show me how to drive since your such an expert driver. have you been to classes at a real race track. has you friends and family attended skip barber training out in CA? do you autocross regularly? drag race regularly? i do....i own a 92' Talon TSi with more mods that you can imagine that i run at the track as well as a 300zx NA that i take to a SCCA autocross sanctioned event every other week to autocross. Dont go around assuming that i cannot drive b/c i am a very well educated driver except i've never had so much problems with one part on one car as i've had with that damn clutch. i may drive the car to its limits but i do so knowing that im trying to push the car to the edge b/c i enjoy it and thats how all cars should be driven. the 7th gen civics were not made to be race cars yet to be an affordable and economic way to get around and just because i dont like a part doesnt mean im not allowed to voice my opinion and that OH NO! im a bad driver b/c something fricked up. maybe you should learn to just lay off a little before you go assuming **** when you dont know me one bit......i wish you lived closer so i could challenge you to ANY event in a car so you can see who's the better driver...geez i hate some people sometimes
Old Sep 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
lol im not the one who went threw 3 engines and 2 trannys ..... and you should know like u stated, your obviously abusing the wrong car...and if you hate me so much.. then leave.. your the N00bie here not Me.
Old Sep 16, 2003
What determins how hard you have to push on the clutch? someone last night told me its the flywhell but it didnt sound right?
Old Sep 16, 2003
pressure plate
Old Sep 16, 2003
i like a clutch that is easy to push in so what would be a good aftermarket clutch that can handle a turbo and is easy to push in ?
Old Sep 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
act Extreme .. IMO... what determines if its good for a turbo is its HP rating.
Old Sep 16, 2003
MadWheel's Avatar
where should I buy ACT products from?
Old Sep 17, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
lol, i live about a mile from the ACT main building. Maybe i should print this out and see if they'll give me a free clutch so i can promote their stuff!
Old Sep 17, 2003
LOL
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
JetsterDajet
Aug 15, 2015 08:07 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
