can't get the oil pan plug out!!!
Old Aug 31, 2003
general_jung's Avatar
general_jung is an unknown quantity at this point
Angry can't get the oil pan plug out!!!
tried usin wrench... almost stripped the hell out of it.
that thing is torqued tight as hell, used some wd-40 but still won't work.
do you guys know what size socket i need, i'm goin to go buy it after the labor day holiday cuz it's too late today.
any other input on how to remove it will be appreciated.
Old Aug 31, 2003
mig's Avatar
mig
mig is an unknown quantity at this point
it's a 17mm socket. make sure your socket drive is set up to drive the oil pan bolt counter clockwise. then just get on it.
Old Aug 31, 2003
n/m i found that the size for the bolt is 17mm from a previos post.
i just hoped that i can still get that thing out... man it's stripped pretty bad
does dealer sell the bolts?
Old Aug 31, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
u can get new ones at any automotive parts store...just tell them the make/model/year..they'll have it behind the counter...
Old Aug 31, 2003
Vinh's Avatar
i had the same problem....
my bolt is almost stripped too
here's the solution:
do not use a socket wrench
instead use the 17mm wrench
Old Aug 31, 2003
Vinh's Avatar
errr....this one
Old Aug 31, 2003
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
if it stripped too badly get another nut welded onto the existing one and then just pick up a new one from honda
Old Sep 1, 2003
skipbarber's Avatar
i used a socket wrench and then slid the handle into a lacrosse stick...behold the magic of leverage.
Old Sep 1, 2003
thanks for the replies peeps.
yea i went out and got a 17mm socket
the bolt was stripped so bad i couldn't fit the socket at first
so i hammered it in using the ratchet and then torqued the hell out of it and it finally gave in.
salvo and pepboys did not have my parts... they only stocked up to 2000 models. went to the dealer but their service dept was closed because of Labor Day. so i had no choice but to put the bolt back on.
anyways.. i switched to mobil 1 5w-20 synthetic oil, and the engine sounds quieter and feels smoother, or maybe it's just in my head. I was thinking about getting Quaker State but decided to go with the more expensive brand cuz i thought it might be worth it.
Old Sep 1, 2003
skipbarber's Avatar
i use mobil 1 5w-30 ...well that was this last oil change before that i used castrol syntec 5w-30...i'll be switching back to castrol next time.
Old Sep 2, 2003
i heard someone say that we should change to 5w-30 for the cold weather because the oil might freeze if it gets too cold. Is this true?
Old Sep 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The torque spec is 27 ft-lbs if I remember right... whats the big trouble? Take a 17mm socket, and turn it counterclockwise.
Now that it's stripped, you'll probably have to drill it and hope you can remove it with an easy out. Either that or grind 2 new flats on to it and use a box or crecent wrench to get it off.
5W-30 solidifies at something like -40 deg. F. I doubt you'll have a problem.
Old Sep 2, 2003
01EMCVC's Avatar
01EMCVC is an unknown quantity at this point
make sure you use a crush washer with the drain plug and put on a new one every oil change...flat side of washer should touch pan and round side should touch plug
Old Sep 2, 2003
pheaton's Avatar
A descendant of 2k1civic.com
lol . noooooo
Oil is petreloeum based. . it's not gonna freeze. .
However, it can and will get more consistant (thicker) when it's cold. So just be gentle on your car when you first start it . Give the oil a chance to heat up and flow better.
It's the same thing when it drains. . If you are draining it when it's hot it's gonna pour out of there really fast. . If your car is cooled down, it's gonna take longer to drain.
Old Sep 3, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hehe ... the magic of leverage. How about somebody behold the magic of cleavage?
Vaguexo
Jun 13, 2015 04:11 AM
Mercilus
Jun 7, 2015 10:00 PM
jmdcivic
May 20, 2015 09:52 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
