body kit issue
Old Aug 27, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
Unhappy body kit issue
hey, i have the kaminari kit, and for some reason, my driver's side Side Skirt always gets distorted. it LOOKS normal, but every morning, i have to bend it down because it gets in the way of my door. i can't open my door without pushing it down. i've had the kit for about 5-6 months now and never had this problem before. just lately i noticed that it does that ALOT whenever it rains. anyone know any solutions? is there anything i can do to fix it? any input will be appreciated, thx!!
snort
Old Aug 27, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
can you take a pic? I've heard of this problem before but im not sure what to picture exactly. VietGuy949 has the same issue...
Old Aug 27, 2003
Snort2001's Avatar
i dont have a digicam...but think of it this way...you walk to your car and you open the door. the door will get caught on the top part of the side skirt and since it is polyurethane...the side skirt stretches outwards... if you pull the door out more....the side skirt will keep stretching until it lets go and slams back and hits the car. that's what happens.
Old Aug 27, 2003
Elite's Avatar
Elite is an unknown quantity at this point
the side skirt moved up too much you need to retape the whole side skirt to get rid of the problem I had the same problem with my xenon side skirts I accidently didn't see it comming then bam scratched my side skirt and now you can see black its not that noticable though. I had to redo that whole side.
Old Aug 27, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
could be solved by using some 3M industrial strength double sided tape
Old Aug 27, 2003
Snort2001's Avatar
i tried taht already. i unscrewed all the screws front back and underneath and retaped it with double sided 3M tape, and the problem is still the same. one thing werid is that ever since i got my side skirts new from kaminari, they never fit snug against the side of the car...it sticks out..especially the passenger side. should i contact kaminari and let them know? i doubt they'll be able to do anything since i've had it for so long already.
Old Aug 27, 2003
7thgen Man-gina
unfortunately i dont think theyd do anything for you. it wouldnt hurt to contact them and see if they have any info they can give you. if you had a pic i think it would be a lot easier for everyone to help you, try and borrow one from someone if you can and good luck
Old Aug 27, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I have the same problem WHENEVER IT RAINS!
Although mine doesn't go up, but out, leaving a gap between the door sill and the side skirt. But usually only when it rains. When it;s dry and warm, it tightens back up flush against the door sill. I think it's actually warping with the climate change, it softens, and becomes more flexible.
I don't have a solution, the only thing I can think of is when we painted it, we used to much flex agent in the paint - something your supposed to add to paint when painting polyurethane, but that's just a guess. I am stumped and frustrated as you. Keep me informed.
Maybe its something we should contact Kaminari about, I know a lot of others have had these same problems.
Old Aug 27, 2003
HotDamnItsDavid's Avatar
HotDamnItsDavid is an unknown quantity at this point
My Kaminari side skirts pops out in the middle too. I have them off right now until I get some automotive double sided tape.
Old Aug 27, 2003
Elite's Avatar
Yeah um in the heat it flexes a lot and the cold weather makes it easier to get back together.
Old Aug 28, 2003
Snort2001's Avatar
it's actualy the opposite of that...flexs in the cold and tightens in the heat.
oh yea, you CAN'T use double sided tape for the middle part of the skirt where it pops out...i tried that already, there is no way it will stick, cuz it's only a thin line on top, and there's nowhere the double sided tape can stick to. you can try, but i dont think it'll work. i'm gonna see if i can buy a digicam tomrorow and take pics. i need one anywayz, lol. gonna send an e-mail to kaminari and ask em out it too.
Old Aug 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
hey osofast had the same problem... he took like four screws and screwed the kit to the inside of the door track along the bottem.. u cant even notice.. thats probally the best thing to do... it keeps the kit on perfectly.... and stops it from moving and scratching the paint.
Old Aug 28, 2003
Snort2001's Avatar
wait..can you explain that again???...where do you screw it?? i currently have 4-5 screws in the side skirt underneath the car.
Old Aug 28, 2003
obzerv's Avatar
obzerv is an unknown quantity at this point
screw it on the top...the top part of the skirt u see only when u open the door.
Old Aug 28, 2003
Elite's Avatar
I was talking about the body kit not the installation.
Old Aug 28, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
its those cheap double sided tapes, my g5 kit is comin off too, bout to superglue this sucka
Old Aug 28, 2003
Snort2001's Avatar
that means i would have to screw it into the side of the car where it's painted....
like i said before...the middle part of the side skirt doesn't come taped...and they can't be taped...
Old Aug 28, 2003
jimmy_civic's Avatar
jimmy_civic is on a distinguished road
go to a body shop and ask them to glue it on,they have a special glue that will make sure it says tight to the car and they eill also use stuff so nothing will go through the small cracks....thats what im gettin done to mine and its been done to a different car with a urethane kit and it works great.
Old Aug 28, 2003
Snort2001's Avatar
but what if you want to remove it in the future? wouldn't it tear off the paint on the car?
Old Aug 28, 2003
yes the paint will peal off,but I want to have mine kept on..also after awhile the 3m tape will stick to your car pretty good and it would take you along time to remove it from the car. I know this from experience and its a b*tch to do especially when the tape glue doesnt want to come off with the tape. Also when you are using the 3m tape,dust and other particles do fall into those tiny holes which will cause rust. Hey Snort2001,whose that chick???damm she's hot!!
Old Aug 28, 2003
Snort2001's Avatar
that's Lee Hyori from F.I.N.K.L. yup..she's a hotty!!!!
Old Aug 29, 2003
obzerv's Avatar
if u wanna get it screwed on, have a shop do it, and then cover the screw with some body filler, and then repaint it, u wouldnt even know its there...thats what some peeps i know did when their **** fell...or, the "glue" u can use is window weld..if u dont wanna screw your car (hehe) but yeah, thats what i have on my skirts, and they been on for what, since jan?
Old Aug 29, 2003
Snort2001's Avatar
well...my skirts are ON, they aren't falling off or anything...it's just the middle part is sticking out. i dont really wanna screw it on cuz it'll leave holes when i take it off. i guess i'll have to figure something out. i was actually thinking about it last night and came up with a solution. LoL...since the skirts block my door....i should just get the lambo door conversion, haha.
Old Aug 29, 2003
dru106's Avatar
ThE CoRRupToR
Screwing on the side wont hurt. Look at mines, u can only see when the door is open and when they drill the hole is very small and u can see it with the door closed without he skirt on.
Old Aug 29, 2003
dru106's Avatar
ThE CoRRupToR
another:
Old Aug 29, 2003
Snort2001's Avatar
u can see the screw hole with the door closed when the skirt is off? do you mean can't see? or am i missing something here...
and what kit do you have? is it the kaminari in the picture??
Old Aug 29, 2003
obzerv's Avatar
u can use window weld...the black glue that holds your windshield on works great! ....but then again, lambo doors arent a bad idea .btw, hows it in vegas man??
Old Aug 29, 2003
Snort2001's Avatar
hahaha. vegas is coo so far. met some 7thgen ppl...theres a lot of modified 7thgens down here! i was surprised. haha..how's it back in norcal?
Old Aug 30, 2003
Tshroom's Avatar
Tshroom is an unknown quantity at this point
My xenon skirts droop every few months when the 3m tape gets ate up by the elements.. Can you get urethane molded to your car?
Old Aug 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
YUP
