Car leaking oil
Old Aug 25, 2003
klam's Avatar
klam is an unknown quantity at this point
Car leaking oil
I did an oil change myself last week and now my car is leaking oil. I suspect that it is the oil filter which I bought from Acura the dealer. The filter they gave me was smaller than previous
filters. I did read on a Web site that Honda was migrating to a smaller filter for the 1.7L Civic/EL engines, so I assumed that what they gave me was this updated filter. However, since I did my oil change last week the car has been making a mess all over my driveway. The filter was smaller, but seemed to thread on properly, and I tightened as best I could by hand (which is the way many people suggest for an oil filter).
The drain bolt looked fine, the washer was replaced, and it was torqued to 30 ft-lbs as per the manual.
Has anybody also come across this smaller updated filter?
Is there anything else that could be causing my oil leak?
I am thinking of jacking up the car again and replacing the filter to see if that helps. I'll have to get under there anyway to see where the leaks are originating from.
Old Aug 25, 2003
Da1lyDr1ver's Avatar
yeah, you should do it soon before you get problems like running your engine without oil.
my guess is its definately the filter. go get another one from the honda dealer.
Old Aug 26, 2003
cdmx's Avatar
Why dont you find out where its leaking (not tryin to be mean)
Old Aug 26, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
^^ agree
Old Aug 26, 2003
cdmx's Avatar
If you find out where its leaking then we will tell ya what the problem is
Old Aug 26, 2003
clownprince's Avatar
Ricerus Maximus
mine too ^^
Take the filter off and see if the O-ring from the previous filter is still on there. If you have 2 on there, that's bad. There should only be the one that is on the filter. Also try to find out where the oil is coming from (also another good reason to keep your engine clean). And you don't have to go to Honda for a filter, Auto Zone filters are just fine.
Old Aug 26, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
I had a problem like this as well. Only I had my oil changed at the dealership. (free perk) Anyways, there is a cross-member right below the filter, kinda shaped like a "u", and sometimes the filter will drip some oil into it. It then will slowly drip out, and make a mess on your driveway. So I took it back, and they took a rag and some brake cleaner, and wiped up all the oil in the cross-member.
I'd say jack up the car, and look for the crossmember. Stick your finger in it and see if it's got any oil in it. If it does, clean it out and wait and see if that got it.
Old Aug 26, 2003
cdmx's Avatar
im bout to go change my oil now....royal purple 5w30 with a K&N oil filter
Old Aug 28, 2003
klam's Avatar
My suspicions were correct. The filter that the dealership gave me must have been incorrect. I've replaced it with a new filter (like previous size) and I don't notice any more leaking.
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
superstanko
Apr 28, 2015 04:38 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
