Intake with stock fuel lines.
Old Aug 22, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
I have a injen short ram intake and was woundering if you have had any problems with the lines melting onto the intake. I have wrapped the stock fuel lines that go over the intake but they still get extremely hot. Next question has anyone swapped over to steel braded fuel lines? Reason why I ask, the stock fuel line is ran with a plastic insert that is wrapped in rubber. Since these lines are high pressure hoses, I am unable to find any hoses like the stock fuel lines. Any Ideas?
Jeff
Old Aug 22, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
As far as I know, NO ONE has had any problems whatsoever with the fuel lines melting onto any intake. I think you'll be safe.
Old Aug 23, 2003
Jeff's Avatar
Well then I believe i will be the first person to say there stock fuel line has melted onto there intake during normal driving conditions.
jeff
Old Aug 25, 2003
Jeremy's Iron
Is there any way you can post a pic?
Old Aug 25, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I've seen it on another car... I can't remember who though. So you aren't the first one with the problem.
The porblem with using SS braided lines, is that out fuel lines are all connected using quick connect fittings, so it would be really difficult to swap it out. You can't just fit some AN fittings on. I suggest that you just wrap the line with high temp silicone hosing. Good to 350F.
Old Aug 26, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
My Injen RD started roasting the fuel line resting on it. You're not alone. Go to www.jegs.com, buy ThermoTec Heat Shield Tape. Its $14.99, you can also find it (or some other brand of it) at any speed shop if you've got one. Just wrap the lines in it where they cross over the intake.
Old Aug 26, 2003
Tshroom's Avatar
Tshroom is an unknown quantity at this point
so thats what that black stuff on my powder coated intake is!! I thought there was just a black residue on those lines.. i guess they are melting..
Old Aug 26, 2003
RoadRunner's Avatar
damn what are you guys doin to make the lines melt ?
Old Aug 26, 2003
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
good thing i have the fipk
Old Aug 26, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
mine is too, but i got the tape. meltage = no more
Old Aug 27, 2003
Tshroom's Avatar
I didnt know the intake got that hot!
Old Aug 27, 2003
clownprince's Avatar
Ricerus Maximus
me either, have to check that out tomorrow.
Old Aug 27, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea INJEN blows.. u need to switch up intakes.. i recently switched impulse's from injen to aem and i got to look at both next to each other.. injen is just poorly designed.. im sure im gonna get flamed by injen owners for that.. but it really is.. their sri.. is not made right at all.. the aem comes NO where near the fule lines
Old Aug 27, 2003
Jap-Euro Fusion
Aluminum conducts a lot of heat. Thats why stock stuff is plastic. It doesn't matter which intake it is, AEM or Injen, they're both alumium and they both get hot. The difference is AEM has the big elbow bend where the Injen just runs out straight. There are plenty of simple fixes to it. They're aluminium for showiness... I'm gonna wrap mine up in the tape, simply because I don't care what the hell it looks like, and I'm tired of overheating it.
Old Aug 27, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Same here, I have an AEM. That intake pipe gets burning hot, and I begin to believe that my aftermarket AEM cold air intake is doing more harm that good. But it may still make up for it in increased airflow. But I know it could be alot better. I am going to purchase some heat wrap, cover my exhaust manifold, and cover my intake in it. Also I am building a custom heatshield for the AEM (due to its crappy location of the filter, right in front of the tranny and fan).
Ninetyatecivic
May 9, 2015 07:48 PM
ORskier
May 7, 2015 04:54 PM
cloudguy
Apr 28, 2015 05:02 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Jeff
Nov 25, 2001 10:01 AM
