help with aem cai install
Old Aug 21, 2003
JCiv03's Avatar
im in the process of installing a cai on a LX, and im trying to take off the baffle housing right now. it seems like the positive battery cable is stuck on, or connected to the intake tube. how do you take this off?
Edit: another problem, it seems like the clutch line's in the way of mounting the filter.. anyone else have thiss problem? help!!
Old Aug 21, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
its not connected to the tube.. and its juss a 10mm nut holdin the nut to the terminal..
Old Aug 21, 2003
JCiv03's Avatar
thanks for the quick reply, its not the bolt, its some black clip that seems to be connecting the battery wire on the positive side to the intake tube
Old Aug 21, 2003
prawdigy's Avatar
ohhh.. i think i juss pulled it off then.. if not.. i guess u could cut that tube cuz u dont need it either way even if u decide to go back to stock
Old Aug 21, 2003
JCiv03's Avatar
thanks for the quick replies prawdigy, i managed to get it off with some pliars.
Old Aug 21, 2003
JCiv03's Avatar
another question.. im putting the tempterature sensor back into the intake pipe.. and it doesnt seen like the cord's long enough... did i do something wrong? like not pushing the pipe down all the way? it seens like the pipe's all the way down though... here's a pic of it.. for the most part, its in, but not all the way in. is it okay if i leave it like this? or what should i do?
Old Aug 22, 2003
reflekt's Avatar
reflekt is an unknown quantity at this point
just cut away a little bit at the electrical tape and pull it to extend enough so that it's not super tight to the point where a bump in the road could cause it to fall out of the plug socket. u wanna give it some slack.
Old Aug 22, 2003
JCiv03's Avatar
thanxs for the input reflekt. it seems like the wire wasnt as tight as i thought. it fits perfectly, kinda. what does that temperature sensor do? is the thing that reads "H" or "C" on the gauges?
Old Aug 22, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
That's fine there.
The temperature gauge is for the water.
Old Aug 22, 2003
JCiv03's Avatar
thanks ak.
another problem. im mounting in the filter, but it seems like the clutch line is in the way. would it be okay if the clutch line was touching the filter?
Old Aug 22, 2003
JCiv03's Avatar
cant seem to get the filter on... the cluch line's in the way.. help!!
Old Aug 22, 2003
JCiv03's Avatar
here's a pic of my problem...
Old Aug 22, 2003
JCiv03's Avatar
ARGG!!!! finally got it in. damn it was a FU**ING B**CH putting that filter in!! good lord!! took me about 2 hours alone! so the grand total time for installing my cai is... 5 hours... damn man...
also, the clutch lineis touching the filter's rubber connector area. is this safe? or did i do something wrong? it shouldnt matter, right?
Old Aug 23, 2003
reflekt's Avatar
hm. i just took a look under my hood and i just noticed the same thing too. the "clutch line", whatever that is, is millimeters away from touching the CAI tubing. anyway. congrats to u for finishing the install. daaaamn. took me 1.5 hrs to install mine. and that included the 20 min waiting to reset the ECU. lol. but at leaest your done now right?!
Old Aug 23, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
i have an ebay cold air.. and when i have the lower part on.. the filter pretty much is touching my tranny...
Old Aug 23, 2003
reflekt's Avatar
when i installed mine, i made sure that the filter wasn't touching the tranny. the filter head is about an inch and a half away from it.
carid
Nov 7, 2015 01:46 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
