adjust ignition timming
Old Aug 21, 2003
detoX's Avatar
detoX is an unknown quantity at this point
has anyone succesfully adjust thier ignition timming? advance and retard?
Old Aug 21, 2003
detoX's Avatar
comon people! i can't believe nobody have done this before???? has it?!!!
Old Aug 21, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
Did you search?
Old Aug 21, 2003
detoX's Avatar
yeah! no luck.
Old Aug 21, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
its all controlled by the ECU, so you would need some kinda controller or something to control it... probably would be big bucks....
Old Aug 21, 2003
detoX's Avatar
yeah i know. any ideas how can i do this?
Old Aug 22, 2003
detoX's Avatar
Old Aug 22, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
i believe that's what JET does. Heard they're not very reputable, though..
Old Aug 22, 2003
xtiszx's Avatar
Cracka
you HEARD, thats hear say, iv used there products, there very good, if they werent i dont think they would be in biz for this long
Old Aug 22, 2003
detoX's Avatar
i tried jet..i emaild them they said they dont retard timming, aslo MSD, my last option know is Haltech the E6K, i think thats what KMS used in their car. anyway..if you guys know somethin that can help me..
Old Aug 22, 2003
detoX's Avatar
damn..KMS said that i sould try MSD so i think Haltech now is out of the question..damn damn damn!
what happens when you dont udjust the ignition timming for a 100 shot of N2O? (with a build engine)
Old Aug 24, 2003
detoX's Avatar
comon guys!
Old Aug 24, 2003
Voiceofid's Avatar
End Bringer
your ignition timing is controled by your computer depend on rpm(crank rotation position sensor) the system advance itself as the rpms goes up
i believe you can advance and retard the timing of a system using the haltech e6k, but i believe it converts the car into a wasted spark direct ignition system, which isn't applied to our vehicles.
if you are not able to retard the syste, for nitrous, a couple things coule happen
1. nothing happens, the car runs just fine
2. the momentum of the crank still carries the piston over top dead center, and the detonation occurs advanced depend on rpms
3. the crank's momentum was not able to carry the piston over tdc, in that case, you are going to break something
someone correct me if i am wrong, i just started learning ignitions
Old Aug 24, 2003
detoX's Avatar
wasted spark direct ignition system? whats that?
so your saying it cant be done on a 2001 civic?
Old Aug 24, 2003
Voiceofid's Avatar
End Bringer
i am sure ignition timing can be done, probably with some sort of computers, i just don't know any as of now, others may but i don't.(maybe aem's engine management system?)
wasted spark direct ignition fires 2 sparks at a time, one spark for the cylinder that needs it, and another at the cylinder across from it, usually that cylinder is at it's exhaust stroke
Old Aug 24, 2003
detoX's Avatar
i've thought about the AEM ems but that thing cost so much..i'de go turbo before i buy that thing. anyway thanks Voiceofid..
Old Aug 24, 2003
Voiceofid's Avatar
End Bringer
what about the haltech e6k? that has timing adjustments doesn't it?
Old Aug 24, 2003
detoX's Avatar
yeah..it sez i does, but im not sure if it would work on our cars, i asked KMS cause they had it in their car(100shot) but i didnt get a straight answer and he said he didnt like the way their car runs..i think he sed somthing you cant retard, so and i emaild Haltech havnt gotten a respons yet..
Old Aug 30, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
why not just an adjustable cam gear?
Old Aug 30, 2003
detoX's Avatar
that only adjust the cam timming not ignition timming..
Old Aug 30, 2003
SpdRcrChk's Avatar
BOOST JUNKY
Yeah i realized that last night after reading up on it a bit....
http://sportcompactcarweb.com/inside...technology01a/
Old Aug 30, 2003
detoX's Avatar
? whats that for?
Old Aug 30, 2003
SpdRcrChk's Avatar
BOOST JUNKY
its about cam gears. it's actually a review on AEM's cam gears too. Helps out a bit.
Old Aug 30, 2003
detoX's Avatar
ah, but the one i need is to adjust the timming. thanks anyway. i've seen that
Old Aug 31, 2003
Voiceofid's Avatar
End Bringer
yvette, i believe our cars will adjust the timing of everything else according to the change of cam gears degrees, the adjustible cam gears are so much easier back in the older honda because they have distributor ignition, but now, we have computer controlled coil, the computer controls every aspect of our timing, it will retard and advance it's own timing curve according to the change on the cam gears, i see no point to spent the money on those cam gears, for our cars any way. i don't belive it will yeild anything significant either on the rsx. my instructors said he has seen computerized ignition timing adjust itself a full 200 degrees (back in the distributor days, he said the max was about 45) thus, you might actually limiting the car's by say, advance the cam degrees by 5 degrees (that's 10 degrees of crank shaft rotation) doing that may cause our ecm to freak and retard the timing to say.. 10-20 degrees ATDC(which pretty much neutralize anything you did to the cams, because the spark timing will be retarded, thus i won't even bother with the cam gears
just my 2 cents
Old Aug 31, 2003
SpdRcrChk's Avatar
BOOST JUNKY
So Id....you're saying that the suggestion that people make to retard the timing by approximately 1.5 when usung a larger than a 50 shot of nitrous on our cars would really be pointless?
Old Aug 31, 2003
detoX's Avatar
he's saying that you cant retard the ignition timming by simply retarding the cam gear like you said, on older honda cars you can but on a 2001 civic its diffrent
Old Aug 31, 2003
SpdRcrChk's Avatar
BOOST JUNKY
Yeah I understand that much.
As i told you before i read up on it a bit the other night.
But here's a possible solution. I don't remember if it's been mentioned previously within the confines of this thread...but MSD offers a product that can prolly help us in this. However...it's a bit pricey.
http://store.summitracing.com/produc...?p=3854&view=2
Old Aug 31, 2003
detoX's Avatar
i emaild MSD before..heres what they said..
Dear Sir,
Due to the individual coil/module assemblies in your vehicle we do not offer any products that will work on your vehicle.
Thanks,
MSD Tech
Old Aug 31, 2003
MadWheel's Avatar
Premium Boosted Member
damn, on a previous response I saw, about Jet... I know you are looking at retarding your ignition so Jet is out of the question, but the response you got from them doesn't say they do not touch ignition timing, they do in fact ADVANCE it by 5 degrees. I have the Jert chip, its better for bolt-ons but a no-no for forced induction.
