Timing Advance Instructions
Old Aug 21, 2003
KaZeLL's Avatar
KaZeLL will become famous soon enough
Post Timing Advance Instructions
Ok i recently took a trip to ebay and seen this thing for sale about adding 7-20 HP by advancing your timing with a resistor, you had to buy it for 15 bucks...wow $15 for a resistor and some instructions on where to put it...any ways this is what the instructions say..
" Its a little knows racing tip that you can unplug your IAT ( intake Air Temp) sensor and u will trick the on board computer into thinking that it's 32 degrees out ( creating a rich fuel mixture). the down side to this is the pcm realizes that there is no signal returning from the IAT sensor & will cause a SVS light to come one. SLP Engering has an override kit for GM (which sells for $75 ). And you get the same result for less. Useing an ohm meter we determined that the resistance going through the sensor was 3.3k ohms when the outside temp was about 32 degress. So the resistor acts as a jumper and returns a 3.3kohm load to the ECM ( by passing the sensor itself ). Returning the 3.3kohm will cause the ECM to look up the optmal air/fuel mixture temp ( when it wormer outside, this will cause a rich air fuel mixture ). a rich fuel mixture will help eliminate any potential detonation. In turn advancing you spark timing a few degrees resulting in a HP gain of typically 7-20 HP depending on the vehicle."
Well i just finished installing it and took it out for a test drive, ( IT DID WHAT IT CLAIMS ) , being that i do have an air/fuel meter i noticed the differance in the meter readings from stock and with the mod..as for the gains i would say about 5 - 7 hp. As of now I'm rolling on heavy as 18" chromies and its always difficult to get a good jump ...with this mod i was able to fill the difereance in pick up...
I'd say its wrth the buy....only takes about 15 min to install and I've had no problems with any sensor so far...
here's what you need ............ (1) 3.3kohm resistor @ 1/2 volt tolerance ( orange, orange, red, gold)
How to install ..
1) Locate the IAT (intake air temp) sensor located on the back side of the RUBBER BOOT between your throttle body and MAF housing and unpluge it. ( this sensore sits right next to the rubbor boot by the intake whole of the trottle body ) you cant miss it.....
2) With the IAT harness unplugged bend the resistor into a "U" shap and insert it into the plug ( not the one connected to the thrttle body......the plug)
3) with the resistor snug in the harness, just tape up the harness with electrical tape so that no water gets in there, and if you want do the same for the sensor connected to the thrttl body..
4) thats it your done
happy moding........
Old Aug 21, 2003
CivicHX01's Avatar
so the car is gonna run rich? i'm no engine tech but isn't the engine gonna wear out faster and mpg should become way lower??
pics?
i'm always interested in DIY low priced mods
us civic owners be ballin on a budget imp:
Old Aug 21, 2003
KaZeLL's Avatar
pretty much every mod you do puts stain on the motor and causes it to run differently cuz its not the way it was intended to run, uhh hate when people post such things as this, you dont always have to run it this way, its a resistor, come on it takes 2 sec to remove and take out to put backe to stock..
But i will try and get some pics out when i get the chance...
Old Aug 21, 2003
dj02's Avatar
pics?
mpg will go down, as for it running rich probly will be so, just use 89 or 91 octaine so u getter a better response. I've seen that resistor thing and I think its bougas but I never tryed it so I don't know for sure. I would like to try it to see if it does work. and as far as it messing ur engin up probly but like kazell said just take it off and only use it when u go to the track. its what I would. and drivetofast said that it would mess up ur exgaust mani and that it dosent do **** his a honda tech and said he see it all the time but then again he likes to talk lmao!
Old Aug 21, 2003
CivicHX01's Avatar
i'm not putting down this mod or anything... i just asked some honest questions and i just needed some reassurance before i do this thing... looking forward to the pics...
Old Aug 22, 2003
KaZeLL's Avatar
will get them out asap, na na not getting mad, its just that every one is looking for that greater HP gains and when some one post up somthing good about a mod people r quick to put down and say I dont belive it and talk all this trash about it and it bugs the crap out of me, not saying thats what your doing, but untill you try u will see,
i think its pretty safe..benn driving around with the mod and the car seems to run fine, still tripping on the new meter readings on the air/fuel meter , yes i have been running rich, but the metter has never stood in rich befor at idle befor the mod...now it does..
Old Aug 22, 2003
Handsonme's Avatar
Coolios. Easy way to boost hp. Cheap too.
I think I have at least 2 to 3 grand on mods on car --- my car looks neither tricked out nor runs noticeably faster -- LOL
If you are looking for HP, then I think this is a great cheap idea. =D
Old Aug 22, 2003
KaZeLL's Avatar
lol....thats a good one, all i know is that i can take off faster to come to a screaming halt a 120.....no good, not like i hit top speed on the track anyways......
Old Aug 22, 2003
Handsonme's Avatar
u top out at 120?
why is it that i have gone faster?
hmmm.......
weird.
Old Aug 22, 2003
KaZeLL's Avatar
well like 123 or so...but for sure no higher that 127..
Old Aug 22, 2003
CivicHX01's Avatar
well i went off and bought the resistors from radio shack, 5 for 99 cents... i did notice a difference but i've only recently installed my rvm pulley yesterday so i don't know how much power i got from the pulley and how much from the resistor mod... but definitely with both i notice a big difference in acceleration... i was surprised too because 5th gear accelerates pretty good now too... but this is all from my butt dyno of course
i also noticed that my temperature gauge acts differently too... even though the car was just driven a few minutes ago, it stays really low until you start it and drive around a bit...
but before, even though i had my car parked for like 30 min, the engine temp was still like 1/4 of the way up in "acc" before starting....
and governer kicks in at 120 too (i think its more like 117 or 119)... 2k1 hx
Old Aug 22, 2003
KaZeLL's Avatar
wow glad to see this mod help you out, acceleration on the free way is great, damn car pulls now...its great...i would for all of you who want a good mod with gains try this one, you cant go wrng for 99 cents....lol and 10 min of your time. want a bigger gain, for ***** and gigles try runnung the car with out the filter on your first run, damn its almost tempting to leave the damn thing off....lol....but ya the real test is the dyno....
Old Aug 22, 2003
VNlilMAN's Avatar
The Standard One
i think imma try this...
Old Aug 22, 2003
NoFriends's Avatar
I like ruining your threads.
ditto, im gonna pick up the parts this weekend too
Old Aug 22, 2003
CivicHX01's Avatar
i got extra ones... $1 shipped!
haha jus kidding... jus go get at radio shack .99 for a pack of 5 but you only need one... there is definitely that extra kick after doing this mod...
Old Aug 22, 2003
CivicHX01's Avatar
Talking
Old Aug 22, 2003
CivicHX01's Avatar
resistor installed...
Old Aug 22, 2003
VNlilMAN's Avatar
The Standard One
ey andrew you going to the meet this sunday? if so hook it up mang...
Old Aug 22, 2003
CivicHX01's Avatar
shiny strut bar... lol
Old Aug 22, 2003
CivicHX01's Avatar
didn't want the thing all loose hangin around so i taped it under where it used to be... (and hopefully my parents don't notice a difference lol... looks messy for now imma redo it in a minute...
Old Aug 22, 2003
CivicHX01's Avatar
full engine bay...
spark plug wire cover from prodigy's car RIP... his car lives on thorough mine (got his ex tweeters too)
recently painted heat shield
Old Aug 22, 2003
CivicHX01's Avatar
oops forgot to attach the pic...
Old Aug 22, 2003
CivicHX01's Avatar
i want to go but i dunno if i can yet... if i do i'll bring them for sure and help install... its easy and quick
Old Aug 22, 2003
KaZeLL's Avatar
cool thanks for the pics, i just got ahold of a digi cam and was going to take a few pics but since did it...cool...
Old Aug 25, 2003
VNlilMAN's Avatar
The Standard One
thanks andrew for the resistor... i can feel my car picks up better. nice cheap way to gain a lil more power..
Old Aug 26, 2003
VTECTypeR's Avatar
What is the resistor called so i can pick it up from radio shack
Old Aug 26, 2003
CivicHX01's Avatar
3.3k-Ohm Resistors 1/2 watt 5% tolerance
Old Aug 26, 2003
CivicHX01's Avatar
i took mine out temporarily because my gas mileage dropped drastically with this mod... the gas prices are just too high right now and its taking its toll on my wallet... i keep it in my car and i'll put it back when i feel i need the extra gain or when the gas prices start dropping... it only takes a few seconds to do it..
Old Aug 26, 2003
KaZeLL's Avatar
ya there was a guy or 3 on here who thought i was a fool for buying such a thing...now look who's the fool, I think it waz iron fist, and two other clowns, there like this shi^t doesnt wrk....WHAT DO YOU KOW TILL YOU TRY GUYS, all this was of course about the helix but i added that in to and i felt a difference as well.....
"i set the trendz.....lil boyz"
Old Aug 26, 2003
VNlilMAN's Avatar
The Standard One
kazell you ****in gangsta... but then you got raped $15 so
