Clearing Headlights - Removing Bumper
Old Aug 20, 2003
smark_ca's Avatar
smark_ca is an unknown quantity at this point
Question Clearing Headlights - Removing Bumper
i am going to clear my headlights. Do you have to remove the front bumper or can you work around it. I saw the post where you had to remove it. I am hoping it can be done with the front bumper on....
Old Aug 20, 2003
jer2k's Avatar
jer2k is an unknown quantity at this point
From everything Ive seen the bumper has to come off.
Old Aug 20, 2003
JCiv03's Avatar
yup, it needs to come off
Old Aug 20, 2003
KeNsHiN's Avatar
LEVA
they are not mounted arould the bumper but behide it. so yes you have to remove it , but it is cake
Old Aug 20, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
follow the DIY.. its the only way to do it.. dude if u take out the lights without removin the bumper .. i want pics so i can laugh.
Old Aug 20, 2003
DaSilviC's Avatar
DaSilviC is an unknown quantity at this point
u really dont have to remove the entire bumper.....side the screws at the sides and the clips on top of the grill......and then pull a lil and you can work with the bumper hanging
Old Aug 20, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
lol what else is there to remove after that? the bottem clips? Remove THE BUMPER.
Old Aug 20, 2003
fuRiousVIC's Avatar
fuRiousVIC is an unknown quantity at this point
the housing.. need a heat gun for that
Old Aug 20, 2003
civicvtec1ps's Avatar
Search and Learn
its very easy to take out front bumper anyways. just do it
Old Aug 20, 2003
FALKEN's Avatar
Civicforums Junkie
save yourself the headaches and just take the bumper cover off...ive done it numerous times before and it seriously only takes like 5mins.
Old Aug 20, 2003
smark_ca's Avatar
Thanks guys...wish me luck ....hopefully no special trips to Honda's parts dept.
Old Aug 20, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
lol should be a theif i can take that **** off in seconds ive done it so many times.. lol
Old Aug 21, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
for the best result: make sure you use some masking tape to tape around the black adhesive stuff, so when you pull the insert out, so that black adhesive wont stick on your chrome part.
Old Aug 21, 2003
Phanibal's Avatar
Phanibal is an unknown quantity at this point
Just follow the diy man it really is the only way, mine came out clean from doing the diy
Old Aug 21, 2003
g_50b's Avatar
g_50b is an unknown quantity at this point
i just got in from clearing my headlights. THe hardest part was taking out the chrome part from the headlights.
Old Aug 21, 2003
azn215's Avatar
azn215 is an unknown quantity at this point
You really dony have to move your frony bumper all you have to do is open up the front bumber enough so you can stick the wrech to remove the screw under the headlight and dont forget th e screw next to the fender
Old Aug 21, 2003
cryption's Avatar
2003 Nissan Frontier
you should have just searched instead of posting a new topic. However, while you have them apart you could paint them too. Results look like this .....
Old Aug 21, 2003
Voiceofid's Avatar
End Bringer
i remember back in the day, when i was freaking out about removing my front bumper, now, i pop it on and off almost every other day, lol you are not going to break anything, just relax
Old Aug 24, 2003
biohazard's Avatar
biohazard is an unknown quantity at this point
cryption: painted his lights? I can't really tell. What color were they painted? It looks kinda shadowed. Is that the intention?
Also, when you clear headlights, do you HAVE to have a yellow bulb there? I didn't think you did, but I saw civic HB the other day, with cleared headlights, but a yellow bulb there, so it just got me to thinking...
Old Aug 24, 2003
clownprince's Avatar
Ricerus Maximus
Remove the red screws/clips, pop sides of bumper and pull forward, remove green 10mm screws, remove headlights. Simple as that. Especially if it is the first time you've taken the bumper off and you are scared of scratching it up.
Old Aug 24, 2003
Neptune's Avatar
Neptune is an unknown quantity at this point
the DIY is not very informative when it comes to actually doing the clearing!
everyone keeps asking about the bumper, thats the easy part. but i want to know more information about actually clearing the headlight.
what is the best way to seperate the case? do you use hair dryer?
i am concerned about puting it in the oven so i want to use a hair dryer.
also, how do you re-Seal the headlight? do you buy caulk?? laytex? how do you get the head light back together.
this is the kinda stuff i wanna know. i am going to be doing this today, and i need some extra help so please post some specifics. THANK YOU. also if you have a link to a thread that explains what im asking that would be great too.
Old Aug 24, 2003
ericscorpse's Avatar
ericscorpse is an unknown quantity at this point
or like this....
Name:	my blue car headlights.jpg
Old Aug 24, 2003
Originally posted by ericscorpse
or like this....
or this...k, so mine are not cleared but they are painted which I think looks nice
Name:	my blue car headlight.jpg
Old Aug 24, 2003
and now to actually help a little bit...after they are removed I popped off the little metal clips....these are very obvious. I used a small flat tip screw driver to seperate the lens from the light assembly (just be gentle), after I painted the junk I just slapped them back together and there was enough sealer left from before to seal them again. I have been through 4 or 5 very hard rains recently and no leakage problems at all.
Old Aug 24, 2003
Neptune's Avatar
ok thanks , i think i might pick up some sillicone at home depot though, just to be safe!
Old Aug 24, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
^^^Paranoid much? I never used anything but the orig. sealant and I too have had no problems. Don't worry so much.
Old Aug 24, 2003
biohazard's Avatar
Can anyone answer my light question?
I asked if you needed to replace the bulb with a yellow/orange bulb if you take out the colored corner. I don't think so, but I saw a Civic HB with cleared lights, but colored bulbs... made me paranoid.
Someone please help settle my paranoia!
Old Aug 24, 2003
if u wanna be legal then get an amber bulb (most states). Like a dollar or 2..oh and don't get like blue or anything like that....cops can give u tickets for that
Old Aug 24, 2003
biohazard's Avatar
Thanks for the info... Now to decide whether I'm willing to risk having all white in the headlights. I think it looks cool, but paying a fix-it ticket isn't nearly as fun...
Old Aug 24, 2003
Stick the lights in the oven to loosen the glue. Then stick the pieces back in and use the original goo to seal em back up.
