what will happen after engine swap?
Old Aug 19, 2003
mcwoowoo's Avatar
mcwoowoo is an unknown quantity at this point
Question what will happen after engine swap?
I just want to know can it still be legal for engine swap if you purchase the engine legally?
do you have to update some numbers at DMV? smoke check still pass? any other problems or trouble?
thanks
Old Aug 20, 2003
alpinersx's Avatar
alpinersx is an unknown quantity at this point
Which engine? The K20A or K20A2?
Old Aug 20, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
oooooooooh good question. big difference!
Old Aug 20, 2003
alpinersx's Avatar
Well if it's the K20A2, then I don't see what the big deal would be. It has been done by many (Base RSX and Civic owners) and it's a USDM engine so emmisions wouldn't be an issue. I wouldn't worry about the DMV or insurance, you'll just end up getting screwed by both of them.
The K20A swap has also been done and could be an issue with emmisions. Hondata has a flash for the ECU that makes it run on 91 octane so I think that would help.
Old Aug 20, 2003
mcwoowoo's Avatar
I'm get the Type-s engine, K20A2.
So my car will still be legal?
Old Aug 20, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
Well if it's the K20A2, then I don't see what the big deal would be. It has been done by many (Base RSX and Civic owners) and it's a USDM engine so emmisions wouldn't be an issue. .
Old Aug 22, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
As long as your K-series motor is the SAME YEAR AS YOUR CAR OR NEWER You will be fine.
You CAN NOT (legally) put a 2002 K20 in a 2003 Civic.
Old Aug 28, 2003
DathAnEteRnaLbBLuE's Avatar
DathAnEteRnaLbBLuE is an unknown quantity at this point
just swap your motor you will be fine, if its a usdm motor then there is definatley no problems and im pretty sure that same year or newer rule is only applied in some states. Keep this in mind, if you blew your engine you would have to get a new one. no changing anything at dmv or emissions tests or anything like that besides i dont think your gonna get stopped for running a stop sign and the cop is going to ask you what motor you have in there because you ran the sign faster than other cars
Dathan
Old Oct 30, 2003
HondaLuver's Avatar
Its a celebration bitches!
if you get a k20a you really wouldn't have to worry since it says honda on the valve cover. you can just tell the officer that is the stock engine that came with the car...
beneditti
Jan 15, 2016 12:31 PM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
