diy a/c control relocate
Old Aug 11, 2003
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
i know ima need fiberglass paint andwhat not but how do i extend the wires do i exted them one by one or is there a kit or something??
Old Aug 11, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
nah to extend the wires its called cut and tape.
Old Aug 11, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
just out of curiousity .. where u relocatin them to?
Old Aug 11, 2003
bth Go Army's Avatar
bth Go Army is an unknown quantity at this point
i'd sodder somethin like that.
Old Aug 11, 2003
Island2K2's Avatar
yea i was thinkin bout solderinthem but theres alot of wires and each one man id be there for a while im gonna relocate them to the side of the center concole on the drivers side or under the e-brake
Old Aug 11, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
u can always use those wire connectos.. those are cleaner then using tape...
Old Jan 22, 2004
joedc5's Avatar
joedc5 is an unknown quantity at this point
Use sodder, I do alot of custom wire extending installs for friends and I sodder each one because butt connectors will eventially let up. If you can the best way to do it is to go to Honda and ask them if they have matching connectors that is the amount of feet you need or longer and if longer strip each wire and use pin tools to set them in the connectors. Try to get matching connectors and line up the pins DON"T MIX THEM UP!!
Old Jan 22, 2004
texasric3r's Avatar
texasric3r is an unknown quantity at this point
With a lot of wiring projects I use power connectors from PC's. They have the capacity to hold 4 wires and are easy enough to plug/unplug but normal bouncing around in a car will not cause them to come apart. Also, they are fairly cheap to obtain.
Old Jan 23, 2004
joedc5's Avatar
^^^ That is also a good idea. And alot less probally than Honda.
FutureCivicOwnr
Aug 11, 2015 10:59 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Jul 14, 2015 03:39 PM
