Better handling.. RSX or Civic?
Just Be
Just curious... you'd think the Civic would since the RSX has a heavier motor up front and b asically the same suspension.. I could be wrong though.
Just Be
handles better in what way? road holding.. side to side transition.. under steer? My civic handles pretty good I think. I have sprint springs, front strut bar.. and tires. im getting the rsx bar this week end.. well itw ill be shipped this week end
Ive got my car with 205/40/17s goldlines, front and rear upper struts, rsx rear sway bar...
and my buddy with the type s drives as crazy as i do with just rims
I just remembered that the rsx s's come stock with a front strut bar.
Originally posted by WannaBFast
well i would hope that the rsx handles better cause 1. it has wider tires, 2. beefier suspension, and 3 more balanced
It has stiffer springs and shocks and a bigger rear anti-roll bar. It does have a tower to firewall strut bar from the factory, it doesn't look big enough to do much. The car was just tuned for sportyness rather than econoboxing. If you took a stock RSX suspension and put it in a Civic, with the lighter weight and better front/rear split, you'd probably outhandle the RSX, assuming you took acceleration out of the equation.
Autocross Junky
Yup... Stock RSX > Civic
but Because of the weight difference the civic has more potential, weather or not that potential can counter the RSX speed advatage? I don't know. but we'll still be able to pull more Lateral G's then them.
Weight plays a much more important part in Handling then it does in acceleration.
i.e. You can have a very light car handle poorly if its weight is unbalanced (Poor corner weight. bad cross weight ect..).
and Boilermaker1 is right (More then He knows). The US version of the RSX is a modification of the Japanese Version. The Japanese Version is Right hand drive the US is Left. What does this matter? well the Japanese weighted the car to compensate for a Driver on the Right (So there is a little more weight on the Left) The US version has the driver on the Left, so that weight (Originally added to balance the car) now Hinders its cross weights. so the Japanese Version (Stock vs Stock) handles sightly better then the US version (Even though every thing else is the same).
hmm, interesting, I'd have thought this was a stupid question and that the RSX handles much better than the Civic hands down.
Having driven both, I'll say easily the stock RSX is MUCH more responsive than a stock Civic. Never taken the RSX to the track tho, so don't know what it's capable of there, but just every day driving and horseing around, the RSX feels better.
I'd have thought the weight dist. disadvantage the RSX has over the Civic would be fairly easily countered by the vastly better suspension setup, but again, I haven't taken it to the track, so don't know for certain.
just my $0.02
just my $0.02
Autocross Junky
the RSX and the Civic have an almost Identical Suspension. In stock form the RSX was designed for performance, and the civic was designed for economy. what this means is that if both cars were given simmalar suspension mods, the lighter car would have an advantage in the corners. However, the RSX's engine may be able to make up for it in the straights.
SO ....... while the civic may be able to out corner the RSX, the RSX will make up the differenc in acceleration.
Autocross Junky
dosn't look like it. Its heavier then the Base line RSX and just a hair lighter then the RSX-S Though, like the RSX, what it loses vs the civic in the corners, it will make up for in the straights.
Autocross Junky
of course, Stock Vs stock. but because the 2 cars have Virtually the same suspension set up, if both were to be set up Identically, the lighter car (Civic non Si) will have the advantage in the corners. However, I dont think that a Civic will be able to "hang" with either The RSX or RSX-S on a road course because the RSX's have so much better acceleration. (What the civic gains in the corners will be lost in the straigtaways).
I cant comment on how a civic with a K20 swap would do against them because I dont know how much weight is added because of the engine, and I dont know how that weight affects the balance of the car.
I actually think my '03 EX coupe handles as well as, or close to, the '02 base RSX I last drove. I know the suspension/steering was slightly changed on the 7th gens after 2001, and the RSX I drove didn't have any better steering feel or quicker turn in than my Civic, which is bone stock. Also the RSX OEM tires suck just as bad as our 7th gen OEM Firestones, only they have a little bigger contact patch. I think with better tires and really basic suspension mods, I could take a RSX in the corners, but of course, like someone already mentioned, they'd smoke me in the straights. Such is life with a D17.....
What about the weight distribution in an EP3 compared to the RSX and regular Civic? Autocross Junky
I dont have any weights of a 7th gen (Coupe or sedan) but I do have some info on both the Si and the RSX-s.
RSX-S total weight (As weighed by Grassroots Motorsports) 2724
LF 858 RF 839
LR 486 RR 541
This give the RSX-S cross weights of
LF+RR 51.36%
RF+LR 48.64%
7th gen Civic Si total weight (As measured by Grassroots motorsports) + 232 LB driver. 2847
LF 899 RF 820
LR 596 LR 532
this gives the Si cross weights of
LF+RR 50.26%
RF+LR 49.73%
Cross weights are Very important to Handling. 50% is what you want.
SO...... it appears that the RSX-S has a bit of a cross weight problem........ So the US version is Much More unbalanced the the Japanese version, and it looks as the Si (Being designed in Europe) is better balanced but Heavier (Due to the Driver)
SO I was wrong in my assumption, the Si will probably handle better, but the RSX-S's Hp will probably help it to win anyway.
LF 858 RF 839
LR 486 RR 541
LF+RR 51.36%
RF+LR 48.64%
LF 899 RF 820
LR 596 LR 532
LF+RR 50.26%
RF+LR 49.73%
wow, those are 2 really impressive arguments..............
