Better handling.. RSX or Civic?
Old Aug 10, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Just curious... you'd think the Civic would since the RSX has a heavier motor up front and b asically the same suspension.. I could be wrong though.
Old Aug 10, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
I' hope the RSX handles better considering it costs more and bone-stock civics handle like crap.
Old Aug 10, 2003
CiViCLiZeD714's Avatar
i say that the RSX would handle better if both were to compete stock...the rear sway bar helps quite a lot
Old Aug 10, 2003
civicvtec1ps's Avatar
Search and Learn
i liked rsx's handling better than my old ex. when i test drove one.
Old Aug 10, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
i dont remember what it was like to have both cars as stock...
Old Aug 10, 2003
orso's Avatar
orso is an unknown quantity at this point
ive dirven both and the rsx beats the civic by far.
Old Aug 10, 2003
MangoEX's Avatar
Just Be
Is that just cause of the bar?
Old Aug 10, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
defintly the rsx.. the base auto handle's way better than my civic
Old Aug 10, 2003
MangoEX's Avatar
Just Be
handles better in what way? road holding.. side to side transition.. under steer? My civic handles pretty good I think. I have sprint springs, front strut bar.. and tires. im getting the rsx bar this week end.. well itw ill be shipped this week end
Old Aug 10, 2003
RoBBUsaF's Avatar
the only thing i like more about the vic is that is has a way better turning radius.
Old Aug 11, 2003
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
stock versus stock, the rsx because it hugged the road when i drove it, even with those *** tires. both cars are great handlers if modded properly. ROAD COURSES
Old Aug 11, 2003
cdmx's Avatar
Ive got my car with 205/40/17s goldlines, front and rear upper struts, rsx rear sway bar...
and my buddy with the type s drives as crazy as i do with just rims
I just remembered that the rsx s's come stock with a front strut bar.
Old Aug 11, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well i would hope that the rsx handles better cause 1. it has wider tires, 2. beefier suspension, and 3 more balanced
Old Aug 11, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Its not better balanced. Its actually worse as far as weight dist. goes.
It has stiffer springs and shocks and a bigger rear anti-roll bar. It does have a tower to firewall strut bar from the factory, it doesn't look big enough to do much. The car was just tuned for sportyness rather than econoboxing. If you took a stock RSX suspension and put it in a Civic, with the lighter weight and better front/rear split, you'd probably outhandle the RSX, assuming you took acceleration out of the equation.
Old Aug 11, 2003
Zzyzx's Avatar
Autocross Junky
Yup... Stock RSX > Civic
but Because of the weight difference the civic has more potential, weather or not that potential can counter the RSX speed advatage? I don't know. but we'll still be able to pull more Lateral G's then them.
Weight plays a much more important part in Handling then it does in acceleration.
i.e. You can have a very light car handle poorly if its weight is unbalanced (Poor corner weight. bad cross weight ect..).
and Boilermaker1 is right (More then He knows). The US version of the RSX is a modification of the Japanese Version. The Japanese Version is Right hand drive the US is Left. What does this matter? well the Japanese weighted the car to compensate for a Driver on the Right (So there is a little more weight on the Left) The US version has the driver on the Left, so that weight (Originally added to balance the car) now Hinders its cross weights. so the Japanese Version (Stock vs Stock) handles sightly better then the US version (Even though every thing else is the same).
Old Aug 11, 2003
Naito's Avatar
Naito is an unknown quantity at this point
hmm, interesting, I'd have thought this was a stupid question and that the RSX handles much better than the Civic hands down.
Having driven both, I'll say easily the stock RSX is MUCH more responsive than a stock Civic. Never taken the RSX to the track tho, so don't know what it's capable of there, but just every day driving and horseing around, the RSX feels better.
I'd have thought the weight dist. disadvantage the RSX has over the Civic would be fairly easily countered by the vastly better suspension setup, but again, I haven't taken it to the track, so don't know for certain.
just my $0.02
Old Aug 11, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Where does the EP3 fit into all of this? I don't remember it's weight distribution but fill me in considering the engine and driver are on the opposite side like the RSX.
Old Aug 11, 2003
BoSS's Avatar
BoSS is an unknown quantity at this point
Can you switch the suspension from the RSX and use it in our civics?
Like the whole assembly and pop it in our factory slots and have them work?
Hrmmmm......
Old Aug 11, 2003
Zzyzx's Avatar
Autocross Junky
the RSX and the Civic have an almost Identical Suspension. In stock form the RSX was designed for performance, and the civic was designed for economy. what this means is that if both cars were given simmalar suspension mods, the lighter car would have an advantage in the corners. However, the RSX's engine may be able to make up for it in the straights.
SO ....... while the civic may be able to out corner the RSX, the RSX will make up the differenc in acceleration.
Old Aug 11, 2003
ryanjennings's Avatar
ryanjennings is an unknown quantity at this point
what about the 02-03 Si's arent they better than the RSX?
Old Aug 11, 2003
Zzyzx's Avatar
Autocross Junky
dosn't look like it. Its heavier then the Base line RSX and just a hair lighter then the RSX-S Though, like the RSX, what it loses vs the civic in the corners, it will make up for in the straights.
Old Aug 11, 2003
Dr5D's Avatar
i think the rsx-s (havent driven the regular rsx) handles much better
Old Aug 11, 2003
Zzyzx's Avatar
Autocross Junky
of course, Stock Vs stock. but because the 2 cars have Virtually the same suspension set up, if both were to be set up Identically, the lighter car (Civic non Si) will have the advantage in the corners. However, I dont think that a Civic will be able to "hang" with either The RSX or RSX-S on a road course because the RSX's have so much better acceleration. (What the civic gains in the corners will be lost in the straigtaways).
I cant comment on how a civic with a K20 swap would do against them because I dont know how much weight is added because of the engine, and I dont know how that weight affects the balance of the car.
Old Aug 11, 2003
AZD17A2's Avatar
AZD17A2 is an unknown quantity at this point
I actually think my '03 EX coupe handles as well as, or close to, the '02 base RSX I last drove. I know the suspension/steering was slightly changed on the 7th gens after 2001, and the RSX I drove didn't have any better steering feel or quicker turn in than my Civic, which is bone stock. Also the RSX OEM tires suck just as bad as our 7th gen OEM Firestones, only they have a little bigger contact patch. I think with better tires and really basic suspension mods, I could take a RSX in the corners, but of course, like someone already mentioned, they'd smoke me in the straights. Such is life with a D17.....
Old Aug 11, 2003
VtechChronicle's Avatar
VtechChronicle is an unknown quantity at this point
RSX
Old Aug 11, 2003
AZD17A2's Avatar
Civic!!!
Old Aug 11, 2003
Zzyzx's Avatar
Autocross Junky
wow, those are 2 really impressive arguments..............
Old Aug 11, 2003
MangoEX's Avatar
Just Be
hehe
Old Aug 11, 2003
All Eyes On Z
I guess I should've been more specific. What about the weight distribution in an EP3 compared to the RSX and regular Civic?
Old Aug 12, 2003
Zzyzx's Avatar
Autocross Junky
I dont have any weights of a 7th gen (Coupe or sedan) but I do have some info on both the Si and the RSX-s.
RSX-S total weight (As weighed by Grassroots Motorsports) 2724
LF 858 RF 839
LR 486 RR 541
This give the RSX-S cross weights of
LF+RR 51.36%
RF+LR 48.64%
7th gen Civic Si total weight (As measured by Grassroots motorsports) + 232 LB driver. 2847
LF 899 RF 820
LR 596 LR 532
this gives the Si cross weights of
LF+RR 50.26%
RF+LR 49.73%
Cross weights are Very important to Handling. 50% is what you want.
SO...... it appears that the RSX-S has a bit of a cross weight problem........ So the US version is Much More unbalanced the the Japanese version, and it looks as the Si (Being designed in Europe) is better balanced but Heavier (Due to the Driver)
SO I was wrong in my assumption, the Si will probably handle better, but the RSX-S's Hp will probably help it to win anyway.
