Subwoffer question
Subwoffer question
sup peeps i just bought a new sub yesterday poweracustics daul voice coil
and i hooked it up the way it said in the instructions so am using both coils..
now my amp is getting relly hot and turning off and on on me cause it over heating
dose any body know what the best way 2 hook up a daul voice coil sub to a 2 channle amp?
gonna need more info to help you out like the power rating on the sub and amp ...if the amp is bridgeable ect.
mod should probably move this to ICE so more people can help
Originally posted by Chenz
ur not runing the amp stable... u need to find what OHM the amp runs and run the speakers at the same OHM.... thats why its heating up ... ur gonna blow ur amp if you dont match the OHMs
didnt think about that
ok the amp is a 600 watt kennwood and yes it is bridgeable
the sub is i thing 900 watt daul voicecoil poweracustic...
i hooked the the sub up like this ran the - to the other side of the - for the voice coil
and hook the + to the other + the ran the amp - to - and + to +
the its bridged to my amp now which am using a - from one of my channles and + from the other
i be better with a diagram so sorry if am confussing
will you make out with me
Don't run it like that. Just hook it up as if it were two different speakers. Don't combine any of the wires in any way. You MIGHT be able to get away with it if your amp is stable to 2 OHMs in bridged mode, OR if your speaker is 2 OHMs per coil you can run it in series and get 4 OHMs out of it. Anyway, neither of those is probably the case, so just run it like you would two different speakers. Forget all that bridging stuff. Any more questions ask me, I've done installs for about 8 years now. I know a thing or two.
-Keith
-Keith
Go to www.RockfordFosgate.com They have wiring diagrams for different combinations. As far as a cap I don't think you'll need one. I heard they were a waste of money.
Byrd-
Definitely not a waste. Helps a lot. I've got a Sony Xplod 1000 watt amp pushing two Pioneer 500 watt subs. The Cap prevents the dimming effect when ever hard bass hits. So it's something I would recommend getting.
A descendant of 2k1civic.com
Originally posted by cdmx
he wont blow the amp...it has that safty feature where it will cut off when it gets too hot..whats it called some sort of special circuitry
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
see that ? thats the worlds smallest violin.
