2doorvs.4door
Need....More....Mods
wow!!!
thats it for weight dif...but how....i'm assuming the 4 door is longer to make room for the doors...i figured it would be a couple hundered pounds....at least 200! wow...so performance should be about the same comparing 5 speed models????
Difference is that 4 doors gets 4 people in and out faster. Safer for people with babies. More carrying space for your groceries and will get you from point A to B within +/- 0.0000001 secs faster/slower than a coupe.
Well, if you've ever noticed, and im sure you all have, the doors on the coupe are really long to allow for backseat entry (that sounds weird) and they're also a lot heaveier. The doors on a sedan are fairly light, especially the rear doors. The car is slightly shorter, as someone mentioned, but its also taller, also mentioned. So really it was taking the same dimensions and weight and reworking them into a 4-door and only adding a barely noticeable weight. So really, i dont think there'd be much of a difference between the two.
it makes sense now that i think about it...cause my coupe doors are huge compared to the sedans.......wow...i always just assumed there would be some sort of performance difference.
well obviously it depends on the driver......a stocker vs one with i/h/e and pulleys...that can be a drivers race too if you have a semi bad driver in the modded vic and a good driver in the stocker...thats why i love vics. Mods can even up the playing field but its mostly a drivers race.
Autocross Junky
Sedan was designed in Japan, coupe was designed in California, Hatchback was designed in Europe. Styling differences show it all.
e-married to daydreamer
do you know if it's possible to swap the chrome trunk piece w/ the lights for the plates for the panted piece on a coupe? are the measurments the same? visually, they look it.
Prowlin' with a Purpose
well there isnt much of a weight difference between teh sedan and coupe.. so that much is neglegable.. u should conisder the profile of each of the cars... the coupe has a shorter roof and the angle of teh windshield is shallower but again.. its a civic.. so it dont really make too much of a difference either way
Originally posted by ShowCivicLX02
I'd think that a 5spd coupe wood b lotta faster bc of weight and I guess aerodynamics....
