2doorvs.4door
Old Jul 21, 2003
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
2doorvs.4door
how much slower is a stock 4 door than a stock 2 door?
Old Jul 21, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
not much considering the weight difference between teh 2 is like 47lbs or so... thats goin off of teh 5spd sedan vs 5spd coupe
Old Jul 21, 2003
02civic's Avatar
wow!!!
thats it for weight dif...but how....i'm assuming the 4 door is longer to make room for the doors...i figured it would be a couple hundered pounds....at least 200! wow...so performance should be about the same comparing 5 speed models????
Old Jul 22, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
The sedan is actually a cm or two shorter than the coupe. The chassis is the same, that 1 or 2 cm difference is actually from bumper design. nothing really.
Old Jul 22, 2003
WannaBFast's Avatar
well the wheelbase, and overall dimensions are the same, except the sedan is a little taller
Old Jul 22, 2003
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Difference is that 4 doors gets 4 people in and out faster. Safer for people with babies. More carrying space for your groceries and will get you from point A to B within +/- 0.0000001 secs faster/slower than a coupe.
Old Jul 22, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
Well, if you've ever noticed, and im sure you all have, the doors on the coupe are really long to allow for backseat entry (that sounds weird) and they're also a lot heaveier. The doors on a sedan are fairly light, especially the rear doors. The car is slightly shorter, as someone mentioned, but its also taller, also mentioned. So really it was taking the same dimensions and weight and reworking them into a 4-door and only adding a barely noticeable weight. So really, i dont think there'd be much of a difference between the two.
Old Jul 22, 2003
02civic's Avatar
it makes sense now that i think about it...cause my coupe doors are huge compared to the sedans.......wow...i always just assumed there would be some sort of performance difference.
Old Jul 22, 2003
WannaBFast's Avatar
the only real difference if any is the handling, the center of gravity is lower on the coupe because the roof isnt as high like 2"...
Old Jul 22, 2003
Green Civic's Avatar
Depends on the driver.
Old Jul 22, 2003
02civic's Avatar
well obviously it depends on the driver......a stocker vs one with i/h/e and pulleys...that can be a drivers race too if you have a semi bad driver in the modded vic and a good driver in the stocker...thats why i love vics. Mods can even up the playing field but its mostly a drivers race.
Old Jul 22, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
I thought the coupe came from the sedan chassis, not the other way around
Old Jul 22, 2003
Zzyzx's Avatar
Autocross Junky
Sedan was designed in Japan, coupe was designed in California, Hatchback was designed in Europe. Styling differences show it all.
Old Jul 25, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
well I've got the coupe and my bro's got the sedan. Both 5-speed and the coupe feels a lot faster. It also feels as if the gears are different. Maybe just me though.
Old Jul 26, 2003
AR's Avatar
AR
e-married to daydreamer
do you know if it's possible to swap the chrome trunk piece w/ the lights for the plates for the panted piece on a coupe? are the measurments the same? visually, they look it.
Old Jul 26, 2003
ShowCivicLX02's Avatar
ShowCivicLX02 is an unknown quantity at this point
I'd think that a 5spd coupe wood b lotta faster bc of weight and I guess aerodynamics....
Old Jul 26, 2003
WannaBFast's Avatar
well there isnt much of a weight difference between teh sedan and coupe.. so that much is neglegable.. u should conisder the profile of each of the cars... the coupe has a shorter roof and the angle of teh windshield is shallower but again.. its a civic.. so it dont really make too much of a difference either way
Old Jul 27, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
2-doors do not = faster car when comparing the same car on the same platform. You would have to put 4 big *** coupe doors on a sedan to make some logic out of that.
Old Jul 27, 2003
blackcivic28's Avatar
blackcivic28 is an unknown quantity at this point
Yes, the hood molding does fit, I put it on my sedan. I am in the process of ordering the trunk license plate molding (in black, same as the hood molding). And that will also fit.
