Front Sway Bar?!
Old Jul 20, 2003
hkyuppies's Avatar
hkyuppies is an unknown quantity at this point
Front Sway Bar?!
What is the original size of the front sway bar?!
I've seen many articles about installing RSX rear sway bar,
does anyone consider their front actually?!
Old Jul 20, 2003
Grey's Avatar
DIY King
It depends what year Civic you've got. The '01's and '02's have a 25.4mm front sway bar. The '03's have a 15.9mm front sway bar. I guess if you've got an '03, then you could upgrade to the '01's or '02's front sway bar. You'de also need to upgrade the rear sway bar to even out the handling though. I have an '01 front sway bar off of my LX for sale. Along with everything you need to install it. Check it out: FS: 2001 Civic LX Front Sway Bar & Bushings & Brackets & Bolts
Old Jul 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The stock 25mm front and the 19mm RSX rear actually gives you a pretty neutral combination... so there really isn't much of a need to change it. Besides the RSX front is bent differently since the engine is on the other side of the engine bay.
Old Jul 20, 2003
Zzyzx's Avatar
Autocross Junky
also, by increacing the roll resistance on the front of the car you'll more then likly end up with more understeer. I think thats why Honda went with the smaller bar on the later models. (that also depends on the spring rate of the 03's too).
any one konw where we can find the stock spring rates?
Old Jul 22, 2003
HondaLuver's Avatar
Its a celebration bitches!
they are worth it
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
