Speed sensor location
Old Jul 19, 2003
g_50b's Avatar
g_50b is an unknown quantity at this point
Question Speed sensor location
Hey i need to change my speed sensor clip, can anyone tell me where it is? a pic would be very helpful. thx..this is for a 01 civic lx (non-vtec). ps. im new.
Old Jul 20, 2003
g_50b's Avatar
no one knows?
Old Jul 20, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
i know where it is at. why do you need to change the clip? it shouldnt be messed with.
Old Jul 20, 2003
XtremeJM's Avatar
im not quite sure what your asking, but if your saying you want to disconnect your speedometer, thats pretty easy
Old Jul 20, 2003
gipperkid's Avatar
illegal...odometer fraud....up to 5 years in prison and 10,000 fine
Old Jul 20, 2003
g_50b's Avatar
no man, not disconnect it. my guages turn off on my..like the needles just drop to 0...the only thing i was told that could fix this is
1) make sure the cluster is plugged in
2) check the speed sensor clip
3) check ecu wires
i have done 1 and 3 and everything is plugged in so the last thing i need to check is my speed sensor clip.
Old Jul 20, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
When my gauges are off, the needles are at 0, thats how it should be... what exactly are you trying to do?
Old Jul 20, 2003
g_50b's Avatar
when im driving...the needle just drops to zero. I am trying to fix that.
Old Jul 20, 2003
g_50b's Avatar
actually i think im just going to take it to the dealer and pay to find the problem. ppl on here r gonna think im trying to stop my OD.
Old Jul 21, 2003
XtremeJM's Avatar
Oh....my car did that before, ended up being my altenator.
Old Jul 21, 2003
g_50b's Avatar
weird...mine tends to jump to about 100...then come back down...die...and so on
Old Aug 6, 2003
Mr.Modify's Avatar
hey mines does the same thing except my cruise control light flickers and everytime it flickers my speedo drops to zero and then will go back to normal then back t ozero again bye they way!!! where is the CLUSTER, SPEED SONSOR CHIP AND ECU WIRES?
Old Aug 7, 2003
g_50b's Avatar
i have no idea..no one on here would tell me where the speed sensor clip was...
Old Aug 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I'm guessing here... so if I'm wrong oh well. Lift up the car and look on the back side of the hub on the right front. There's a probe of some sort that is directed at a "gear" that isn't hooked up to anything, but it rolls on the hub. That might be it. Maybe you can trace it back somewhere.
I'm trusting that you're doing this to fix the problem and not creating an illegal one.
Old Aug 7, 2003
flotsamm's Avatar
Are you referring to the VSS(Vehicle Speed Sensor)? If you looking to replace it, its not illegal to. In my Helms manual, it says:
1. Remove the intake resonator.
2. Disconnect the 3P connector from the VSS.
3. Remove the mounting bolt, then remove the VSS.
4. Install the VSS in the reverse order of removal.
From the pic it looks like its on top of the tranny, under the intake resonator.
Old Aug 7, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Same here... on my old car though.
Old May 5, 2007
circularlogic's Avatar
circularlogic is an unknown quantity at this point
Re: Speed sensor location
How did you know it was your altenator? Have the same problem with my daughter's 1988 Civic. Can anyone help?
97-DX-Lover
Jun 14, 2015 06:07 PM
Rushfan1
May 6, 2015 01:20 PM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
