AEM brake pad problems
Old Jul 13, 2003
VTECTypeR's Avatar
Question AEM brake pad problems
I just got my aem brake pads installed but now its making these noises. As if its a worn out brake pad. The sound comes and goes. I even resurfaced the rotors. Dont know whats the problem
Old Jul 13, 2003
dru106's Avatar
ThE CoRRupToR
Maybe you forgot the backing plate grease.
Old Jul 13, 2003
Weaponx12o's Avatar
how long have you had them on? maybe they're still breaking in. ive heard people say that AEM pads squeel with OEM rotors. that might be another problem
Old Jul 13, 2003
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
the break pads squeel when they are cold or wet .. once they warm up tho, the sound goes away
Old Jul 14, 2003
VTECTypeR's Avatar
It still makes a sound when its hot too. ITs wierd it only does it some times.
Old Jul 14, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
oh yea, you can't SLAM on the brakes for the first 200 miles or so.... it's called the break-in period.
Old Jul 14, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I just installed the AEM pads today with some drilled/slotted rotors... no noise whatsoever... I really like the way they feel, my front end is much smoother now when I brake, My OEM rotors must have been warped or something. Anyways, I paid 100 for the rotors and 50 for the pads so for 150, it was one of the best mods I've done so far.
Old Jul 14, 2003
VTECTypeR's Avatar
What kind of rotors did you get IDQcivic
Old Jul 15, 2003
IDQcivic's Avatar
I got the Brembos from irotors.com
Old Jul 15, 2003
Dr5D's Avatar
wow, i was trying to decide between the AEM and EBC greenstuff pads, im glad I chose the greenstuff!
Old Jul 15, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
squeeks and squeals are caused by two things. 1, being the pads are worn and thus the pads will squeal, and 2, if they are not proporly greased they will squeal also. they make brake pad grease, and also this tacky adhesive spray that you can use too, stops squeeks. stops the majority of friction of metal to metal contact, friction = virbration, vibration = squeeks/squeals.
Star1967
Jun 8, 2015 04:23 AM
rhvic
May 22, 2015 03:06 PM
ayoitzjulesdx98
May 14, 2015 08:29 AM
bsmiley
Apr 27, 2015 01:27 PM
