Signal Help!!!
Old Jul 9, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
Signal Help!!!
Hi, my signal lights are messed up! Okay to the point...my passenger side one blinks like 5x faster than my driver side one and the driver side one stays on (when lights are on) on a solid beam. Help please!!
Old Jul 10, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Make sure the lights are grounded properly. Did you do anything to the lights?
Old Jul 10, 2003
jedi's Avatar
jedi is an unknown quantity at this point
Do "our cars" have flashers ? or is that out-dated?
If there is a flasher unit , it may need to be replaced.
Old Jul 11, 2003
cosmo's Avatar
One of the leads on the passenger side bulb was burned out so I put in 7440's and it works fine, thanks for the help though!
Old Jul 11, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
signals are 7443
check fuses too, under the steering wheel.
Old Jul 14, 2003
TommyC225's Avatar
TommyC225 is an unknown quantity at this point
yea if u put on 7440 the bulb it will not stay on on a solid beam
u have one 7440 and the other 7443 so that sloves the problem with that !!!
as for ur other problem my buddy had the same problem with the fast blinkers just check the wire that connects the bulb it may be lose --
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
meicalnissyen
Sep 25, 2015 12:12 AM
