how to install tyc projectors????
Old Jun 28, 2003
kaizen's Avatar
kaizen is an unknown quantity at this point
my projecters just came in, and before i go install em i was wondering if there is anything i should know. i noticed how there is only one cable connecting the high beam and low beam?? do i have to splice any wires or anything, thanks
Old Jun 28, 2003
NeonImpact's Avatar
Forum Sponsor
Ill be nice before you get flamed on..
1. Remove Bumper (see DIY)
2. Remove 4 Bolts All Around Headlight Housing
3. Remove Old Headlights
4. Install TYC's
5. Put 4 bolts back in
6. Plug in TYC Connector install Factory Connector
7. Turn on Lights and Test
8. If Working, Line up against a wall and adjust
9. See bottom of this page for adjustment procedures.
10. Put bumper back on
11. Go Cruise.
12. Learn to search the site
13. Thank me
14. Have Fun
** No cutting, splicing, opening, nothing!**
**BTW, Nice car man!**
How To Adjust:
**TO MOVE BEAM UP on the DRIVER-SIDE**
turn the outer(lower) screw counter-clock-wise
**TO MOVE BEAM UP on the PASSENGER-SIDE**
**TO MOVE BEAM TO THE RIGHT (towards the plate) on the DRIVER-SIDE**
turn the inner(upper) screw clock-wise
**TO MOVE BEAM TO THE LEFT (towards the plate) on the PASSENGER-SIDE**
(Thanks to falken for that DIY on previous thread)
I know you'll be sure to ask in the near future so check back for this if needed:
WHAT BULBS ARE IN THE PROJECTORS??
High Beams - H1
Low Beams - H1
Parking Lamp - 194
Turn Signal - 3457 (3156, 3157 work also)
Best Bulbs to Buy?
I have worked with MTEC, Eurolite, And Many Others and yes, every bulb will be bright just about, so its your choice of opinion..
MTEC are bright as hell and prolly the highest rating on the site.
Stock bulbs have worked for me perfectly fine, so its your decision..
Remember about laws against the bulbs..
The best way to go is get a H.I.D. Kit made by phillips or out of a lexus, bmw, or whatever..
Hope this helps..
Old Jun 28, 2003
FALKEN's Avatar
Civicforums Junkie
((((SEARCH))))
jk...good post impact
and thanks for the props!!
Old Jun 28, 2003
024drlx's Avatar
024drlx is an unknown quantity at this point
question when you beam on a garage door on a level surface how you adjust the projectors.
i mean like by Example the light stop at a ft above the garage door and a ft below surface that i know that it is center.
do yall guys take your stock beam them to some surface and mark it and put your projectors and try to have the same mark as the stock ones on the surface.
Old Jun 29, 2003
kaizen's Avatar
ya thanks neon impact, but as soon as i wrote the post i went outside and did it in half hour hehe, i was tired and being stupid. thanks for all the info homio, we need more people like you on this site!!!!!
Old Jun 29, 2003
NeonImpact's Avatar
Forum Sponsor
no problem, glad to see that you did it, and im just here to help!
Glad to see you got some..
Old Jun 29, 2003
FALKEN's Avatar
Civicforums Junkie
your welcome
Old Aug 6, 2003
runner1738's Avatar
why is it necessary to remove the front bumper, is it because you cant reach something or what? also what is an average time of just installing them since i read that it took someone 45 min just to adjust them?
also which bulb is for the low since i got mtecs for them
Old Aug 6, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
cuz u need to take off the lights, there is a bracket holding the light to the car.. its under the light.. H1 are the high and low beams
Old Aug 6, 2003
FALKEN's Avatar
Civicforums Junkie
the answer to this question is in this thread...didnt you read through it??
and yes...take the bumper cover off and save yourself the grief of trying to work around the thing...it takes me like 3min. to get mine off
Old Aug 6, 2003
runner1738's Avatar
yes i did read through this thread, i meant on the projector itself since the high and low are both h1 i wasnt sure which bulb to replace on the projector
Old Aug 6, 2003
runner1738's Avatar
so on the tyc projector itself which bulb is for low beam? since i want to replace the bulb before i install them
Old Aug 6, 2003
Kape's Avatar
Kape is an unknown quantity at this point
the projector is for low beam the other (inner) light is for high... and I'm sure these things can be found if you just do a search
Old Aug 6, 2003
runner1738's Avatar
i did but i wish people would make a diy explaining all of this and putting it in the diy section then no one this would be necessary, but no one seems to take the time to make them anymore
Old Aug 7, 2003
Kape's Avatar
DIY is for something you actually DO YOURSELF, there's nothing DIY about which light does what, that information should be in the box that came with the lights. But you know what, if it takes 5 minutes to figure it out on your own, it only takes 30 seconds to post a thread and have people answer your questions, so go for it.
Old Aug 7, 2003
NeonImpact's Avatar
Forum Sponsor
not all belongs in the DIY section..
im gonna lock this thread...
read my post above for all my answers...
and maybe search some more?
thanks to all who gave answers too..
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
