How do you take off our door panals?
Old Jun 24, 2003
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
I remember their use to be a DIY on it but I can't find it...
Does anyone kno how to do this???
Thanks
-Alex
Old Jun 24, 2003
azure's Avatar
There are two screws where the door latch is. A screw a holding the door handle in place. After taking off the door handle, there is another two screws. After that, just pop the door panel right off.
....... I think that's pretty much it, if I recall correctly.
Just a note: you might want to take off the black triangular piece on the corner of the window. The piece where the side-view mirror is. There's a big scratch on mine because I put on the door panel while that black triangular piece was on.
Old Jun 24, 2003
skipbarber's Avatar
look at my member pics, or follow my DIY. its just what azure said, pull off the cover inside your door latch (2 screws), lift up the tiny cover on the door handle (1 screw), pull off the door handle and the triangle trim piece behind the mirror. remove the screws that were under the door handle (2 screws). starting from the lower corner, pry apart the door panel, once you have popped off the sides and the bottom, just lift up the door panel and there you have it. you'll have to twist the door latch a bit to get it out.
Old Jun 25, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Hey man! Ain't seen ya here for a while. You over on beyond or what? Anyway, to remove your door panels follow the DIY HERE . I gotta pull off my panels as well, but I'm getting my friend with his Dremel to cut some mounting rings for my speakers. He's got the router jig, to make sure it's a nice round hole. Hope that helps man.
Old Jun 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
http://robnkester.com/gallery/view_a...umName=album07
krazykoncepts
Sep 8, 2015 09:02 PM
First Car
Sep 8, 2015 08:54 PM
Brad Andrew
Sep 8, 2015 08:22 PM
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
