busted low beam bulb
im from tx. i found out that my right low beam bulb does not wor
. now can i get pulled over if i drive around without 1 headlight? i have foglights btw and i always use em...
. now can i get pulled over if i drive around without 1 headlight? i have foglights btw and i always use em... Registered!!
Yes you can get pulled over, and yes you can get a ticket for it. But most cops will tell you to fix it and give you a warning. But go get a new one and fix it, it takes less then a minute to replace a bulb in the headlight. Then you wont have to worry about getting pulled over.
this sucks! i have piaa superwhites.. so now i have to replace the left headlight blub too(goin back to stock). which means i'd have to take the whole bumper again because my hand won't fit on that side... !@#@^&$%!#! thanks man!
if your passenger side headlight is out they may let you go....but if your driver side is out they will give you a fix it ticket.
No need to take off the whole bumper!! Read your Civic manual!! it'll give you instructions for replacing a headlight, or anyother life on your civic.
Edit: Misspelled "light"... doh!
mr.modify: i didn't even notice that my bulb was busted. i only found out when i was pumping gas and i left my headlights on.
streetglower
lol.. didn't know that..i thought it was easier to take the bumber off rather than mess with the ish in the engine bay. but i have to reseal my left headlight anyway..
jciv03:
"im a hands on type of guy" i wait until i break somehting before i read the manual.. hahah!
thanks for the replies guys!
streetglower
jciv03:
Originally Posted by Asteroid
my bulb's not busted but rather dim on the driver side it's not the fuse either, any ideas?
Hope that helps you. If it was the fuse, then neither of your headlights would work.
Also check your ground for a loose or corroded connection to the headlights.
mjdiaz89
Jun 21, 2016 09:26 PM
15EXCoupe
Jul 30, 2015 12:59 PM
alxz310
Jul 30, 2015 12:18 PM
