Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
Get Better Stopping Power with PowerStop Spring Savings
Old Apr 2, 2025
carid's Avatar
Former Sponsor
carid is a jewel in the roughcarid is a jewel in the roughcarid is a jewel in the rough
Hey drivers,
Looking to refresh your braking system with something a little more performance-driven? The PowerStop 1-Click Z23 Evolution Drilled and Slotted Disc and Drum Brake Kit delivers a full braking solution that’s built for daily drivers who want added stopping power. It includes everything you need—high-performance carbon-fiber ceramic pads, drilled and slotted rotors, coated drums, and stainless steel hardware for a complete replacement.
The rotors are designed to stay cool under pressure with cross-drilled holes and slots that improve heat dissipation and help prevent brake fade. They’re zinc-plated too, so they won’t rust up after a bit of rain. The Z23 brake pads provide a strong bite while keeping brake dust to a minimum, so your wheels stay cleaner longer.
Installation is super straightforward since all components are made to factory specs. Plus, the kit comes with ceramic-based lubricant and premium hardware, so you’ve got everything in one box. Whether you're commuting or cruising, this PowerStop kit gives your vehicle consistent performance and peace of mind.
PowerStop® - 1-Click Z23 Evolution Drilled and Slotted Disc and Drum Brake Kit
https://www.carid.com/powerstop/1-cl...brake-kit.html
Features:
  • Precision machined using a Tru-Cast™ technology
  • Rotor run out is within 0.0015 and DTV tolerance specification is within 0.005
  • All Evolution rotors are mill balanced
  • Rounded slots keep a clear contact patch between the pad and the rotor by sweeping away water, gas and dust
  • Beveled and precision drill holes help keep rotors temperatures down during extreme braking performance
  • All drilled and slotted rotors (except for hub and rotor assemblies) are silver zinc plated to helps shield and resist rust during normal operation
  • Pads, rotors and clips are designed in the precise size and shape of factory OEM parts for proper fit and operation
  • Carbon Fiber infused Evolution ceramic formula for superior braking power
  • The pad surfaces are thermal scorched for a fast break-in
  • Chamfered and slotted like the OE pad to ensure noise-free braking
  • Powder coated backing plate extends life by resisting rust and corrosion
  • Premium rubberized shims provide virtually noise-free-braking
  • Premium stainless steel hardware kit included for easy installation
  • Ceramic based lubricant specially formulated for Z23 Evolution Sport pads
  • Ceramic pad compounds wear slower and last longer than OEM equipment
  • Reduced heat buildup eliminates brake fading that occurs when brake fluid reaches boiling temperature
  • Includes rotors that are cross-drilled and slotted for more effective cooling under heavy use
  • Advanced brake pad compounds produce less dust than OEM factory brake pads
  • Brake pads and rotors offer eliminate squealing under the most extreme cold or hot temperatures
  • Shoes are arc grounded for proper fitment
  • Premium G3000 iron drums
  • Spring and hold-down kits included
  • 3-year/36,000 mile manufacturer limited warranty on the rotors and pads purchased and installed together
Benefits:
  • Slots help to increase pad bite and improve air circulation
  • Drilled Holes and Slots create an escape route for debris, dust, gases, and water
  • Slots clean and de-glaze pad surface for optimum pad coefficient of friction
  • Drilled rotors improve the appearance of your wheels and provide reduced rotor weight
If you want to learn more about the PowerStop brand, please click the link below:
https://www.carid.com/powerstop/info/about.html
Old Apr 2, 2025
carid's Avatar
Former Sponsor
Re: Get Better Stopping Power with PowerStop Spring Savings
Now’s the perfect time to grab a performance brake kit from PowerStop at CARiD.com—during our Spring Sale, you can save up to 10% on select products from March 23 through April 8, 2025. Whether you're looking for better daily driving control or need serious stopping power for your truck or SUV, PowerStop has you covered. Prices are already marked down, so don’t wait—gear up now and enjoy better braking at a better price!
Browse the full catalog of PowerStop products here:
Check out other active promotions and coupon codes:
https://www.carid.com/coupon-codes.html
carid
Feb 28, 2025 05:24 AM
carid
Jan 12, 2021 07:09 AM
carid
Mar 18, 2015 07:42 AM
