Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
How to choose a turbocharger?
Old Apr 22, 2022
Maxpeedingrods's Avatar
Former Sponsor
Maxpeedingrods is an unknown quantity at this point
Correctly identifying the turbo means you’ll get the right replacement first time, saving you time, money, and hassle. In order to supply the correct turbo for your vehicle, we will always ask you for your vehicle make, model and year, or to supply the part number from the Turbocharger either directly from the Turbocharger itself or by contacting your vehicle dealer to get the OEM part number from them. If you are looking to turbocharge a previously naturally aspirated vehicle then you will have to choose a turbocharger that best fits your engine size, bore, stroke, number of cylinders, desired power and torque levels, etc.
You can contact one of our turbo specialists at maxpeedingrods.com for further assistance on choosing the right turbocharger for your application.
WHY BUY TURBOCHARGERS AT MAXPEEDINGRODS?
  • MaXpeedingRods has been engaged in the research and development of high-quality turbochargers for decades. We offer turbochargers at affordable prices, made from high-quality materials and components to ensure desired performance and durability. All our turbocharger housings are accurately cast and all cartridges are fully balanced to ensure a perfect fit and long-lasting boost. All our turbochargers also come with bolting hardware and gaskets needed to bolt them onto your exhaust manifold.
  • Our street performance turbochargers feature a high nickel alloy shell with a temperature resistance of up to 850 degrees C. They feature high-quality journal bearings and benefit from high precision dynamic balancing. High precision cast aluminum compressor and turbine wheels ensure optimized spool-up and ensure reliable performance in the 200-600 horsepower range.
  • Our sport performance turbochargers take things a step further with a stainless steel volute that increases temperature resistance to 1050 degrees C. CNC machined aluminum compressor and turbine wheels ensure greater durability and are able to cope with extremely high boost pressures and RPMs. A stronger bearing structure with improved thrust bearings ensures that our sport performance turbos can support boost pressures of up to 3.0 bar and horsepower ranges of 300-850 hp.
For professional assistance, you can reach out to us via our website maxpeedingrods.com.
Maxpeedingrods
Dec 27, 2021 08:25 PM
Maxpeedingrods
Sep 17, 2021 02:21 AM
dezod
May 6, 2007 08:06 AM
StreetLevelPerformance
16
Oct 6, 2004 10:26 PM
ExospeedRacing
Jun 8, 2004 03:38 AM
