Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
MaXpeedingRods releases SP1 series coilovers
Old Nov 10, 2021
Maxpeedingrods's Avatar
Former Sponsor
Maxpeedingrods is an unknown quantity at this point
MaXpeedingRods has announced the release of the new series coilover SP1,which provides a variety of new features for the MaXpeedingRods’ street performance segment.
Whether your vehicle is suffering from fatigue and high mileage, or if you are in the market to spruce up your overall driving experience, the SP1 series coilovers strike a perfect middle ground between street usability and durability, with performance adjustability and handling characteristics.
Application
Compatible for Honda Civic / CRX 1988-1991 EE EF EC rear fork type
Compatible for Honda Civic 1992-1995 EJ EG EH rear fork type
Compatible for Honda Civic 1996-2000 EK2-EK8
Compatible for Acura Integra 1990 -1993 DA DB rear fork type
note: for some vehicles, you will need sleeves and washers that are already included in our package.
Please refer to the URL for details, https://www.maxpeedingrods.com/produ...x-integra.html
Old Nov 11, 2021
Former Sponsor
Re: MaXpeedingRods releases SP1 series coilovers
Adjustability:
The SP1 series coilovers provide a considerable level of adjustability to ensure every user can tune and tweak their coilover’s settings to provide the best performance.
One of these features is adjustable dampening, with 24 optional settings. Regardless of road conditions, if you are looking for a smooth ride over city streets or the sporty and stiff feel around the apex of a corner, the SP1 coilovers will perform.
Another feature of the SP1 coilovers is an independent shock body, allowing for users to adjust their vehicle's ride height to their needs, while not compromising the spring rate or suspension travel. Consequently, this also allows the user to adjust spring preload without affecting the ride height, resulting in easy spring rate adjustments to change the balance of the vehicle, without adversely affecting its stance.
The SP1 series coilovers also include an adjustable camber and caster plate. This is a substantial upgrade over factory suspension and is also not commonly seen on other suspension options. Given the adjustability in both camber and caster, this allows the user to refine their alignment, further personalizing their vehicle's handling characteristics.
Old Nov 16, 2021
Former Sponsor
Materials:
In street performance applications, finding the balance between strength and weight, and reliability are the key components to an optimal design. MaXpeedingRods has combined both strong and equally lightweight materials to achieve this balance while maintaining reliable operation.
To keep weight down while retaining a rigid structure, the majority of the SP1 coilovers utilize 6010-grade Aluminum. Parts such as the spring perches, lock collars, and the camber/caster plate are all aluminum.
In areas of greater stress and load, the parts materials are upgraded to carbon steel to ensure safe and durable operation. This includes the damper shaft and lower damper housing.
The SP1 coilover’s new damper design includes a revised oil that improves the consistency of viscosity despite temperature change. This allows the damper to sustain a smooth stroke over its entire travel in multiple circumstances.
The spring is of race-grade 55CrSi spring steel, further ensuring strength and reliability
Old Nov 16, 2021
Former Sponsor
Durability:
The SP1 series coilover has undergone rigorous testing both by machine and people to prove strength and reliability. By putting these coilovers in the hands of real people, and also subjecting them to the harsh testing of a machine, MaXpeedingRods have been able to determine that the SP1 series is suitable for street use, simulating both real life and extreme scenarios.
The race-grade springs are also put under their own tests, undergoing up to 600,000 compressions cycles ensuring sufficient tensile strength.
The 24-way dampers have been thoroughly tested for quality before final assembly. Helping increase its longevity, rubber bump stops and boots are installed to reduce dirt and debris ingress.
All components of the SP1 series coilovers have been treated to fair against weather and corrosion. The 6010 aluminum components are anodized, while all other steel components are coated to block oxidation and corrosion.
It is noteworthy that all aluminum components of the SP1 coilovers are CNC machined. Compared to conventional stamped steel or cast parts, CNC machined parts are held to a high level of accuracy to provide perfect fitment every time. Alongside pinpoint accuracy, choosing to machine the material allows for greater resistance to bending such as a stamp steel part, and fewer chances of snapping as a part. Overall, the refined CNC process allows for a higher standard of quality overall.
In conclusion, the MaXpeedingRods SP1 series coilovers are an extremely versatile and robust suspension solution. Higher degrees of adjustability in ride height, spring rate, dampening, caster, and camber adjustments give these coilovers extreme potential in breathing new life in your vehicle. High-grade materials and refined production processes allow for trustworthy strength on the road or on the track.
Maxpeedingrods
Oct 13, 2021 09:10 PM
Maxpeedingrods
May 16, 2018 10:09 PM
