Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
Omni Power Full Coil-over Setup - Top Quality!!
Old Aug 11, 2004
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Talking Omni Power Full Coil-over Setup - Top Quality!!
LOCALS PLEASE STOP BY AND PICK UP A SET!!
When manufacturing a sophisticated suspension system there are many aspects that need to be considered to achieve extraordinary results. After exhausting efforts we feel that we have produced the ultimate coilover system.
We not only wanted a system that performed well on the track but also could be driven on the street. This is not as easy as it may seem, however we feel that we have achieved the perfect combination! Using many of the technologies found in Porsche 911 GT2/GT3 coilovers, we carefully configured bump and rebound settings for each specific application to produce optimum driving dynamics. We used spring (F=10K - 560 ft/lbs & R=10K – 560 ft/lbs) and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability. THe front and rear springs can be switched.
Our coilovers can be raised or lowered, up to 4”, from two separate positions which allows the user to raise or lower their vehicle without affecting spring preload or damper stroke length. We incorporated large 46mm pistons along with 20mm shafts which we found far superior to typical smaller piston/shaft coilovers. By using large 46mm pistons we were able to greatly reduce the stroke length, while still moving the same amount of fluid, resulting in unprecedented efficiency. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. We used CNC Wound SAE 9254 Racing Springs which were found to be the longest lasting spring on the market that showed no tendencies to sag.
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. Omni-Power, Designed and manufactured for customers who demand the very best!
- 46 mm Piston Size, Resulting In Superb Overall Control.
- 20 mm Shaft Designed To Withstand Both Track Abuse As Well As Road Imperfections.
- CNC Wound SAE 9254 Super High Quality Springs.
- Extensive Research And Development Went In To Choosing Precisely Matched
- Spring & Damper Rates Specific To Each Application. The Result Is Outstanding
- Ride Quality & Incredible Handling Characteristics!
Price: $749 plus S/HCall us at 909-982-4927 to order
Locals can stop by and pick-up!!
YOU CAN ALSO ORDER ONLINE: www.robearracing.com
Thanks
Old Aug 11, 2004
VTECTypeR's Avatar
Dam these are a bit stiff. Im sure it would be good on a track but on streets it wouldnt be so good.
Old Aug 11, 2004
Talking
Actually, the set-up is not that stiff. We have tested them on several vehicles, and they ride great! Perfect for the Auto-X guys also!
Old Aug 11, 2004
Jai's Avatar
Jai
Jai is an unknown quantity at this point
Damn I want these..
Just gotta get the cash together..
Old Aug 11, 2004
Thanks for the 1st order!
That was very fast! I am positive the 7thgen community will love these!
Old Aug 11, 2004
wonderz's Avatar
wonderz is on a distinguished road
Hm... how does these compare to Tein, B&G, and JIC full coilovers?
and where in cali are you located for pick up?
Thanks
Old Aug 11, 2004
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Do you ship to Canada? Because I can't find the option for it... Thanks!
Old Aug 11, 2004
Da1lyDr1ver's Avatar
these look VERY similar to the Hayames...
Old Aug 11, 2004
Talking
Yes, we do.
Just call us up, and we can discuss payment options.
Please dont put these into the same boat. We have persoanlly instaleld these on a 7thgen and EP hatch to make sure they work, not one problem has come up!
I also want to point out. We offer a full warranty on these, so no worries, you are dealing with a reputable company!
Any tech questions, please email (do not PM) to me.
Thanks!
Rob
Old Aug 12, 2004
wonderz's Avatar
So how does these compare to Tein, B&G, and JIC full coilovers?
Old Aug 12, 2004
VTECTypeR's Avatar
Are these made by the guy called Omni man or something that made over 200 hp on a B16
Old Aug 12, 2004
Talking
Correct.
Old Aug 12, 2004
wonderz's Avatar
is it me or ppl just cannot see my post/question?
Old Aug 12, 2004
abmerop18's Avatar
Jam out with your clam out.
what post? what question? haha pwned
Old Aug 12, 2004
reytito's Avatar
rob, what year 7thgen was the installation done on? i'm asking for the 03+ civics...
Old Aug 12, 2004
wonderz's Avatar
seriously, was it a bad question or something? I thought it was very reasonable.
Old Aug 12, 2004
abmerop18's Avatar
its a good question
Old Aug 12, 2004
Talking
We have tested on all years except 04, which we dont see any problem.
Thanks
All brands you listed are very repuatable and known brands, i cant compare because everybodys opinion is different, and may be influenced by my personal judgement.
But I can say that these Omni Coil-overs do offer the same quality and proven R&D that customers have grown to expect now-a-days.
We are located in Upland, Ca about 50 miles south of LA
Old Aug 12, 2004
reytito's Avatar
so the coilovers accomodate for the difference in bolt sizes between the 02's and 03's? meaning a separate model for the 01, 02's? cuz i dont see how one model can fit both setups.
dont be offended by the questions, i'm just clearing things up, cuz i think these look kicka$$ and am more than interested...
Old Aug 12, 2004
Talking
I did bring up the differnce with Omni power, they mentioned if you have the pre-load correct, and install the bolt correctly , there will be no problems.
The arm is inveretd so you must put the bolt in upside down for this to work correctly.
Old Aug 13, 2004
dj02's Avatar
how much picked up?
Old Aug 14, 2004
czechcivic's Avatar
czechcivic is an unknown quantity at this point
Originally Posted by dj02
how much picked up?
Id aslo like to know that
Old Aug 15, 2004
02civic_rida's Avatar
ive been reading up on the omni powers from honda tech... and looks like this is what im going to end up going with... just give me a couple weeks and i'll get right back to ya rob...
Old Aug 15, 2004
.............. Wondering... is ther enough people to maybe do something for a group buy?
Old Aug 16, 2004
JCiv03's Avatar
Wow they looks nice. Do these come with a warranty? (ie: if the shocks blow, how would i go about for replacements?) If they're not lifetime warrantied, about how much would replacement shocks cost?
THanks
Old Aug 24, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
I hope they last. There are few of us who've had bad experiences with new products so we'll see.
I'll say they do look exactly like Hayame V2s without suggesting anything negative based on looks. The only difference I see is that the front springs are 10kg while Hayames are 8kg. That could be better since I was getting way too much oversteer with the Hayames (along with the rest of my suspension mods, mind you). I'm pretty sure people will like the go-kart feel of the spring rates Omni offers.
Oh yeah, to help with wonderz question, these are stiffer than entry model Teins, B&G S3s, and the spring rate compares closer to JIC. Again, they are a bit stiffer in the front than JICs. They do share the same spring rate as the Zeal V6 (for DC5s).
Old Aug 29, 2004
technick03's Avatar
technick03 is an unknown quantity at this point
Will these work with the spc camber kit rather than the camber kit that comes with the full set-up ?
Old Sep 3, 2004
2K1Civic17"Gabe's Avatar
I want to know about a group buy as well, in about a month and a half I will get some FOR SURE when I pay my mom off. I have been reviewing everything, and these sound good, especially with the camber kit. I like the go-kart feel part. Group Buy info? Please
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
duyaknow
Nov 23, 2001 07:28 PM
Elusiv1
Nov 8, 2001 10:12 PM
