Cleared lense replacement HL housings!
#37
Rep Power: 0 I'm getting a set of these from dezod.
Which amber bulbs do I need to buy to work with these headlights? Do you fellas that have them have a size or part number?
#38
7thgen Power Maker
1 Post
Rep Power: 0 Originally posted by SQCivic
#41
7thgen Power Maker
1 Post
Rep Power: 0 Attention: This lense requires modification to turn signal. It comes with an adaption piece that holds an 1157 bulb. I have yet to figure out the exact fabrication to make it all work. Will today though!
#42
7thgen Power Maker
1 Post
Rep Power: 0 Originally posted by dezod
#44
7thgen Power Maker
1 Post
Where can you order these sockets?
The sockets can be purchased at any local automotive parts store for $5 each. Very easy mod for an awesome look.
#45
Rep Power: 0 are you sayin the back of the housing does not hold a stock socket. Also would the 1157 bulb stay on constanly or does it just flash when signaling a turn.
#46
7thgen Power Maker
1 Post
Rep Power: 0 Originally posted by HEBEGEBZ
The only other way to avoid this is to somehow make our stock bulb stay in the new housing, which is a larger hole because the 1157 socket is much wider than our stock bulb.
thesushiboy
04-12-2015 02:54 AM
0100010
08-06-2008 09:22 PM
SpoonSportsD17
11-29-2001 02:02 PM
