Archive - Canada Forsale/Trade eh? Only post here if you have item for sale in Canada and will only sell to someone in Canada. Please start threads with your Province, like this: ON: or AB:
FS - 10" rockford fosgate in ported box and kenwood amp
Old Jul 27, 2006
awesome_jay's Avatar
awesome_jay is an unknown quantity at this point
AMP SPECS
KAC-8152D main features:
1,100 Watts max power
300 Watts x 1 max (4 ohms) RMS
550 Watts x 1 (2 ohms) RMS
Wired remote control to adjust boost level and frequency included
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct)
'Kenwood logo triangle' design power indicator LED
2 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Power MOSFET switching power supply
40 amp power supply fuse
Dimensions (WxHxD) : 380 x 61 x 286 mm
asking $150 for the amp
SUB SPECS
10" Punch Stage 2 woofer with molded polypropylene cone
ported 5-/8" MDF enclosure
binding post connectors
frequency response 20-200 Hz
power range 50-200 watts RMS
sensitivity 85.8 dB
Impedance 4 ohms
17-1/4"W x 13-1/2"H x 16"D
the box has screw holes in it from when i had it mounted in the trunk. None of the screw holes go through the wood into the enclosure though.
asking $125 for the sub and box
pickup/delivery in ottawa or if you live near ottawa we can work something out.
wingsfan19
Oct 1, 2015 03:45 AM
JMKendrick
Sep 16, 2015 06:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
99BoostedSi
Sep 7, 2015 04:49 PM
redcloud
Sep 7, 2015 01:45 PM
