Megan Racing lower control arm for 7thgen civic
Originally Posted by linsook
what does this help???
from www.meganracing.com
Originally Posted by BattleEndless
LCA's are an essential part to your car's suspension. When lowering your car your wheels will start to butterfly inward at the top which makes your tires ride on the edge. This increases wear on your tires as the sidewalls are the weakest part of your tire. This also means that there is less tire on the ground which means loss of traction around turns. LCA's reduce camber so that more of your tire touches the ground, keep your tires from rubbing your fender and allow for a wider wheel and tire combination. These LCA's provide light-weight performance with an enhanced appearance to your suspension.
from www.meganracing.comi thought that's what camber kits are for? is this rear lower control arm on it's own like in the picture or does it include the hardware to mount it? it just doesn't look right, like it's missing some parts.
I lower control arm won't adjust your camber unless you specifically buy a shorter LAC then your stock one.
Basically all this will do is provide weight reduction and maybe add a little more rigidity/strength then your stock LCA. Also from behind it will look really trick
WeRkX
Nov 1, 2001 10:33 PM
we've never had any problems with them on our customer's cars..
