Archive - Canada Forsale/Trade eh? Only post here if you have item for sale in Canada and will only sell to someone in Canada. Please start threads with your Province, like this: ON: or AB:
Can anyone burn DVD movies?
Old Nov 11, 2003
nitehawk's Avatar
Just wondering if anyone had hookups to burnt DVD movies here.
I would like to try it on my new Home Theatre system to test the quality of back-ups.
PM me if you can hook me up.
Old Nov 11, 2003
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
I've never tried it.. My dad has a DVD burner in his laptop and I guess DVD burners for PCs are major cheap.. Like 250 bux gets you a pretty good one!
I think it would be worth it regardless of the quality, although the quality will be just as good because it's not being compressed anymore (ie: DivX, Mpeg). The only way you MAY come across loss of quality is from copying a DVD. And that would only happen because it'd be like another step. It's kindof like making a tape of a tape of a tape! Or how about using a fiberglass kit to make a copy over and over.. But I don't think it'd be noticable anyway.
If you do some seaching on the net you'll find how to burn DVDs properally. The only problem is, if your home theatre system will PLAY a burned cd. If it works like a burned VCD, you may have to copy the DVD to your harddrive then burn it with something that makes it like a boot disk.
I hope this helped you a little bit. I'm gonna try burning a DVD sometime when I'm not busy just to see what it's like.. I've done a few DivX's and those were fairly easy. Anyway, goodluck!
Jason
Old Nov 11, 2003
nitehawk's Avatar
Thanks for the tips Jason! I still havent tried it yet but hopefully it works on my home theatre. Let me know if you have any luck.
Old Nov 11, 2003
aznTrance's Avatar
aznTrance is an unknown quantity at this point
my friend can... he burned me a couple of movies... and they work GREAT on my system... its basically the EXACT same thing...
i guess it all depends on how stable your system is when you're ripping the file onto your harddrive... and the speed you burn at... because you always want stability over speed... well in my opinion anyway...
Old Nov 12, 2003
joski's Avatar
Exactly.. If you burn too fast and it does a shallow burn, it will be unstable. I've burned a couple audio cds really fast and they skipped alot because of this.
Old Nov 12, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
Mario, normal DVD movies these days are DVD-9, i.e., double-sided DVDs that hold about 8GB worth of data. DVD-R and +R media are one-sided and holds only 4.7GB (DVD-5). So you can't realistically burn a DVD movie with exactly the same quality.
That said, there are software out there like DVDXCopy (which Futureshop actually sells) that can "compress" a DVD-9 disc into a DVD-R's capacity. And the resulting quality is supposed to be quite good, unless you have a 90" plasma or smthg.
Let me know if you need more details, and also I can hook you up with a drive.
Old Nov 12, 2003
nitehawk's Avatar
Thanks buddy, that is very helpful info! How much would a drive cost? I just got a new Home Theatre system so it would be nice to be able to make back ups
Old Nov 12, 2003
MSoft's Avatar
If you still use a Mac, the external USB drives are quite pricey, like $300~400. Internal drives are around $200 these days, depending on brand. You'll probably want a DVD-Rom for reading as well (~$60) if you don't already have one.
Old Nov 12, 2003
nitehawk's Avatar
I actually have a new Dell system now with with a DVD drive and a CDRW drive. What do you have for that?
Old Nov 12, 2003
MSoft's Avatar
Cool, so you took my advice and gone with Dell, that should serve you well for a few years.
Well, DVD+/-R drive 4x are all around $200ish + tax, Sony or Pioneer would be nice. In fact, the DVD burner burns CDR/RW too, so you can give your CDRW to someone, haha...
Let me know when you'll be in town, and I'll hook you up with one. We should grab a beer or smthg and catch up too.
Old Nov 12, 2003
aznTrance's Avatar
plextor dvd+/-r drives are the way to go!!!!
Old Nov 12, 2003
nitehawk's Avatar
Cool, sounds good buddy,
thanks again.
Old Nov 13, 2003
MSoft's Avatar
Plextor's typically 50-75% more than other brands, IMO not worth it even tho their drives are good quality.
Old Nov 13, 2003
Civic2001Silver's Avatar
Civic2001Silver is an unknown quantity at this point
I hear that LG brand dvd-r/+r drives are really good and are much cheaper than the plextor.
Old Nov 13, 2003
aznTrance's Avatar
lg burners are unreliable, even my cd-rw drive from lg was kind of iffy. the buffer underrun was terrible and such. but maybe it was just my model. plextors are expensive yes, but the quality of their rom drives are unmatched.
check out http://www.cdrlabs.com for full reviews on cd/dvd writing drives.
Old Nov 26, 2003
Was wondering if it is possible to buy an internal burner and put it into one of those external cases and use it as a external burner with the USB port?
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
