Block Guard on ebay
Old May 19, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
Block Guard on ebay
Do we need this with a Turbo?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2415132109
Old May 19, 2003
Robthe54's Avatar
Robthe54 is an unknown quantity at this point
more boost requires more strength from the internals.
if you want to lower your compression (8.5:1) and turn the boost up past 12psi, the block guard certainly wouldn't hurt.
if you looked at the pics from 99blackvtec (i think thats his name- the big-mouth who says he's got like 300hp in his vic) you'll see that looking at the engine deck the cylinders seem like free standing tubes, this block guard adds strength towards the centering of your cylinders helping resist the forces that might cause your cylinser sleve to crack and send a piston out the side of your block.
it might restrict cooling abit, but if you turbo up your car, you might as well upgrade your cooling system anyway...
Old May 19, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
What he said. But it also prevents the cylinder from walking. It gives the cylinder a "base" at the top instead of just the spot where it is planted in the block. I'd say it would be a good thing to have even if the car was running 6-7psi. Cylinders walk over time if you drive hard, even if it's not boosted. That's why they make N/A block guards too... what Black99Vtec had. But for $65-75, you don't have that much to lose if you are going to do other internals at the same time IMO.
Old May 21, 2003
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
block guards are useless in high boost and really only work if you have them welded in and the blocked decked afterwards. you would be better off buying new sleeves.
Old May 21, 2003
Boosted2k2's Avatar
I can't honestly see anybody here running a high boost D17A. By that time... it's not worth the money.
styles234
21
Nov 19, 2019 07:23 AM
jdh022764
18
Nov 3, 2015 06:44 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
zeshan7616
Sep 15, 2015 12:24 PM
rayman009
Sep 12, 2015 08:30 PM
