A3 to a2 direct swap??
Old Apr 10, 2022
Lurkkep3's Avatar
Lurkkep3 is an unknown quantity at this point
Greetings, I’m looking to swap out my a3 for an a2 in my em2. Everything in the front end is from an ep3, as I put a k24 in my ep3.
Subframe, rack, engine, tranny, front suspension and brakes, ecu are all from ep3. With many different accessories and rad hoses from an rsx
The engine went in there with pretty high km’s, and I’ve beat it pretty hard. I’m wanting to boost it and build it for street, with some safe and reliable numbers. I was thinking of just throwing a lower km a3 in but after the research I really don’t think it’s worth the time and money.
my question is if I bought an a2 would it be a direct swap in? I understand I will need a new harness and stand alone to get it running. But otherwise are all engine mounts, and accessories in the same spot? Is the height of the engine the same? (I’ve already have to stack the hood to get enough clearance).
all input is appreciated thanks in advance!
Old Apr 10, 2022
FRSam's Avatar
Click Here
Re: A3 to a2 direct swap??
I believe so. Iirc they’re more or less identical cosmetically.
Old Apr 11, 2022
BrotatoChip's Avatar
Super Moderator
Yes, no issues from K20a3 to K20a2. If you're using the EP3 idler pulley, the hood should clear without issue. If you have a hydraulic power steering pump then you have to notch the hood to get it to close.
Speed9117
Engine Swaps
50
Apr 1, 2014 11:52 AM
michaelcal121
Oct 13, 2012 09:45 AM
fastest_ex
Apr 6, 2009 10:44 AM
RAZRBLD
Engine Swaps
Mar 24, 2006 10:15 AM
ViNRoCk8
Engine Swaps
94
May 19, 2005 11:08 PM
