Engine Swap On 2002 Honda Civic EX - Daily Driver
Old Sep 3, 2020
KaptainKendrick's Avatar
KaptainKendrick is an unknown quantity at this point
Hey All!
I have a 2002 Honda Civic ex and I want to swap the engine out for something that won't have a common head gasket issue. I don't care about horsepower or extra hp, I just want my baby
to make it past 300K miles! She's almost to 200K and I just want her to have a nice life. She's paid for already too. Please help. Thank you!
Old Sep 3, 2020
FRSam's Avatar
Click Here
Re: Engine Swap On 2002 Honda Civic EX - Daily Driver
You’re best off just staying with the d-series that’s in it. My old 7th gen (now my little brother’s) has over 200k miles on it now and I’ve never had to do the head gasket. I bought it at roughly 140k miles and I don’t think it was something that was replaced recently.
The only other option really is to K-swap, which would cost you about $3000 to do yourself.
Old Sep 3, 2020
BrotatoChip's Avatar
Super Moderator
Stay stock and just keep watching the coolant levels and temp gauge. If you start having issues get the head gasket replaced and keep on going. Even if you pay someone to do the head gasket you're talking about $1k, much cheaper than a swap. My head gasket was replaced around 170k miles, took it to 250k before K swapping. Besides burning some oil there wasn't anything wrong with the stock engine.
Old Sep 3, 2020
I got the Head Gasket changed a year ago. I posted another thread where I took a video of how it sounds. Someone told me there may be an air bubble in the system and the water pump on it may not be the right model. I'm not sure where to get a Honda version water pump.
Old Sep 3, 2020
FRSam's Avatar
Click Here
Gates is the OEM for Honda timing belts and water pumps. You can get an entire kit from Napa for around $100.
Old Sep 4, 2020
Link?
Any Honda dealership.
Old Sep 4, 2020
Originally Posted by ezone
Link?
this is the link
https://www.civicforums.com/forums/3...ml#post4761454
And Thank you!
Old Sep 5, 2020
i only heard what sounded like someone whistled very briefly, twice.
Also, no image in the video, it was black.
Old Sep 5, 2020
Yea that was the sound. It sound like someone is whistling, but it is coming from the engine.
And it doesn't do it all the time, mostly when I'm slowing down or idling. Even then, it's intermittent.
Old Sep 5, 2020
I suspect the whistle would be caused by a vacuum leak, though that's just a hunch based only on the sound clip.
Tracking down the source may be a trick. Would help a lot if you can make it make the noise yourself, or the noise becomes predictable or more frequent.
How to find the noise? Maybe a length of hose or tubing held to your ear.... probe around with the free end like a stethoscope,,,,,,where is the noise the loudest, pinpoint the origin or source
Chunk of old garden hose, maybe heater hose if you got some laying around (i have car parts laying around lol), something like that with a good size inside diameter
(narrow tubing like small vacuum hose seems to muffle or deaden some sounds, experiment)
Real quick and obscure checks, maybe:
Does the noise stop if you remove the oil cap?
Does the noise stop if you (SAFELY) loosen the radiator cap? (to relieve pressure in the radiator)
Old Sep 5, 2020
Can a vacuum leak cause overheating?
Also, the whistle sound seems to come it when the fans turn on.
I can't seem to make it happen, it kinda does it randomly. But if I catch the sound again, I will try to work on it. Imma post a picture of a hose on my engine because it has a slit in it and I don't know what the hose is called or what it is even for.
Old Sep 5, 2020
Imma say no not in your case, but if you're talking to other car people some racers may tell you that running too lean can make an engine overheat. That's true but does not apply to your situation.
Clue. If the noise changes or quits as a direct result of when you relieve pressure on the cooling system, it could be coming from the water pump shaft seal.
Old Sep 5, 2020
I don't see Gates on the Napa.com website.
Old Sep 5, 2020
FRSam's Avatar
Click Here
It’s “Napa” brand but it’s all Gates. As someone who exclusively purchases timing belt + tensioner kits from Napa, I can vouch for it.
Just look it up.
Old Sep 5, 2020
That reminds me...Dealer timing belt on the shelf has a gates logo on it.
Didn't have a new pump to check, but i doubt gates made it.
gates.com ?
Old Sep 6, 2020
Idk if this little hose has anything to do with Overheating or aire getting in my system I dont know what it it calles or where to look for another, but it has a small slit on the underside of the hose.
Old Sep 7, 2020
Vent tube, goes to air filter box so PCV system can draw in fresh filtered air.
Atmospheric pressure so its not a manifold vacuum leak, but if it were missing completely you might hear sounds from the throttle area. Just how big is the slit?
AboutTreeFiddy
Engine Swaps
Jan 24, 2018 08:06 PM
austin.james
Engine Swaps
Dec 11, 2014 05:08 PM
hondacreation
Aug 2, 2009 08:30 AM
brancart1
Engine Swaps
Apr 9, 2004 01:29 PM
JUNCiViC
Engine Swaps
Jan 14, 2004 11:51 AM
