D17 Nitrous Questions & help
School is now out for the summer here, and I am planning some things for my car in the next month. I am going with Stage 1 cams, and adding a NX nitrous kit.
http://www.nitrousexpress.com/20421-...lb-bottle.html
Mainly just going to keep it on 35hp, occasionally doing 50 shot when racing. I am not going to take any chances and I am going to do this right!
I just have a couple questions to sort out before I buy the kit.
1. They say you need to spray a minimum 6" from the throttle body, and you must spray after the MAF sensor. On our d17 the sensor is basically located right at the throttle body, how would I make this work?
2. Where would be the best spot to tap into the fuel line for the fuel solenoid? A picture showing this would be great!
Re: D17 Nitrous Questions & help
I'd avoid spraying at the IAT sensor, which is mounted in the air breather housing (or tube if CAI). The rest of the parts on the throttle body you can't avoid anyway.
had to... but link button wasn't working...
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1406& transactionid=1371949751-184657350&posted_by=_www.civicforums.com&youtube_v ideo_id=DDmKr8slxmk[/autostream]
lyanreindecker
Aug 20, 2015 09:15 PM
martinsmartin
Aug 15, 2015 07:34 PM
