compatible engine swaps
Old Apr 20, 2013
hiphop4x4's Avatar
hiphop4x4 is an unknown quantity at this point
so the head gasket on my 02 4dr lx(automatic) keeps blowing and i wanna just swap out the engine...i want to put in one of the higher end engines and was hoping someone could tell me which ones would fit perfectly.
plz and thank you
Old Apr 20, 2013
Re: compatible engine swaps
Why not fix it properly?
Old Apr 20, 2013
GolNat's Avatar
Prelude Owner
Higher end engines?
Search.
Old Apr 21, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
You will spend more on a swap than the car is worth, IMO fix it right. If you keep popping it your mechanic isn't fixing it right.....
Old Apr 21, 2013
quick and easy fix: fix what's causing blown head gaskets, replace head gasket
easiest engine swap: D17A1
This is what you got right now. just plop in a newer one
a little bit of work involved: D17A2 (01-05 Civic US ex/CAD Si)
Almost the same, just a slightly higher compression ratio and it has VTEC, so you gotta get a VTEC controller or use an EX's ECU, but you'd also need to fiddle with immobilizer crap or get it reprogrammed. Will also work with your current transmission.
a lotta bit of work and a good amount of money: K20a3/a2/a engine. (02-05 Civic Si, Acura RSX/-S/-R, respectively)
You're gonna need "custom" motor mounts (or buy the $500 hasport ones), ECU (or kpro) needed, plus the cost of the engine, transmission, sub frame, any fab needed for exhaust ducting, and anything I may be missing. This swap will prolly run you upwards of $5000 (yes, I just pulled that figure out of my ***, but it's also within ballpark range), depending on how cheaply you can find the parts.
http://www.xproductionz.com/k20swap/k20swap.html
This website will give you a good idea of the effort you're gonna need to put in (or the effort you're gonna need to pay for, if you don't DIY)
OPTIONAL: Swap in a K24-- (Acura TSX) or K20 block with K24 head for a bit more power and a bit more of a headache to install, since the K24 head is 4cm (I think) taller than the K20's.
Old Feb 29, 2020
aragon1301's Avatar
aragon1301 is an unknown quantity at this point
hey guys.. i have almost the same problem, but mine is with the Vtec enginge, i want to know if i can put a none Vtec head to my Vtec block,
is this possible on my 2003 civic, i dont care about the Vtec, let me know thanks...
Old Feb 29, 2020
Colin42's Avatar
We've already told you yes like 6 times now, please stop reviving long dead threads to ask the same question over and over
Old Feb 29, 2020
aragon1301's Avatar
sorry i did not see that,..thanks guys
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
