05 civic ep3 k20/k24z3
Old May 23, 2010
FREESPIRIT's Avatar
FREESPIRIT is an unknown quantity at this point
wat u guys think about a k20/k24z3 supercharged.. does any one know how much would i b pushing..i have the type s tranny n head n a k24z3 botom blk.. i just got 2 put it together.. but undecided if i have 2 rebuilt anything or upgrade any parts.. i want 2 b pushing around 400whp or lil less..
Old May 23, 2010
02civicsi02's Avatar
Low and slow!
Re: 05 civic ep3 k20/k24z3
We have to know more. What all is done to the block and the head, if it is not built you are not going to reach no 400 hp sorry. What supercharger and what size pully. Be specific.
I know some one that has a k20a2 that is supercharged on a 4" pulley on 10 psi and tuned and is hitting like 285. Supercharger is alot different than a turbocharger. If you want to hit 400 then go turbo. I am pretty sure that the k24z3 block will be good for at least 12 psi. You might want to upgrade the head alittle. With just that and a good tune you could hit 320 or so. So after that all you need to do is build the block and then push more psi and retune and see whre you get.
You should do some research before messing with boost cause if you dont do it right then you will be sorry.
Old May 24, 2010
FREESPIRIT's Avatar
i only hav stock tranny head n blk.. i will b geting the hondata..i just need some sugguetions on my built..i just wana hit as much possible with a jackson racing supercharger.. the street version.. but i want it 2 boost it as much posible. i need 2 rebuilt the head regardless.. but idk if go oem or after market,,
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
