hp
Old Sep 24, 2008
mr jones's Avatar
mr jones should not be trustedmr jones should not be trusted
hp
i have a 2005 civic with a custom turbo kit.
turbonetics turbo non bb w external waste gate
aem fic
intercooler
walbro fuel pump
injectors
2.5 inch exhaust with no cat and apexi muffler
competion clutch stage 4 6 puck sprung clutch
11 pound competion clutch flywheel
short shifter
18 inch rims with low pros
aem boost and a/f gauges
but i dynoed at 181 whp and 167 wtq at 9 psi. is that enough power or should i be making more. not sure if my tuner is getting every drop of power out. for all the money i put into forced induction i expected at least 220hp with my stock internals. plz i need some advice. yeah im new here but not to cars so if u have neg responses dont even reply.
Old Sep 24, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: hp
220Hp on stock internals? i dont know man, i think that poor motor would explode under that pressure. Besides, youd need a steel HG & ARP studs in the least with those numbers. Prob wouldnt hurt to get them even with what you have now.
Old Sep 24, 2008
mr jones's Avatar
Re: hp
so what you saying is my numbers are good with that setup. what should expect to run in the 1\8 mile
Old Sep 24, 2008
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
Re: hp
stick with one thread
Old Sep 24, 2008
FGCOUPE's Avatar
Re: hp
downpipe will help your turbo spool faster too, i suggest that aswell
Old Sep 24, 2008
mr jones's Avatar
Re: hp
sorry bout the double post. i do have a downpipe. what else u think i can do??
Old Sep 24, 2008
FGCOUPE's Avatar
Re: hp
powerwise....
id say internals first,
cometic HG & ARP studs
Engine management (cant remember if you had?)
dial boost up a few PSI
Old Sep 25, 2008
mr jones's Avatar
Re: hp
can anyone post up their turbo d17 dyno number with factory internals so i can see if im doing good
Old Sep 25, 2008
ronaldo9's Avatar
Re: hp
You're fine you can expect those numbers. What injectors are you running? If you want more than 200whp you'll need something bigger than rsx injectors. Also what size turbo do you have T3 Super 60? T3/4?
Old Sep 25, 2008
andyman97's Avatar
Turbo Guru
Re: hp
Why don't you just search instead of expecting everyone to cater to you and spoonfeed you every piece of information you ask for. ****ing annoying.
Old Sep 25, 2008
mr jones's Avatar
Re: hp
hey bro what is that time of the month for u or some s@@t??? relax man. im jus looking for some power numbers from other d17 turbos. and im looking for some recent numbers thats all. as i hit candyman in the head with a flying knee.......>>>>>>>>......lol
Old Sep 25, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
Re: hp
180whp on what dyno ? dynapack4000 is good ... dynojet its low ... u can get about 200whp on a dynojet
Old Sep 25, 2008
mr jones's Avatar
Re: hp
i was on the dynojet. what u mean i can get 200 on a dynojet??? i see u got 196 at 6psi. what setup u got??
Old Sep 25, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: hp
9 psi and you only made about 10-15 more hp than me....are your injectors maxed out? what are you tuning with? what size turbo?
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
220cc or so injectors should be fine for your 180hp set up, as long as they arent at 100% duty cycle. also noticed the 11lb clutch which will drop some torque #'s off the chart. if your into racing the car then shed off weight like body kits, spoilers, seats, headliner, carpet and even chisle off the tar crap off the floorboards. This all sheds increments off your timeslips some by .03 sec for a few items off the car.
Old Sep 25, 2008
mr jones's Avatar
Re: hp
not sure if they are maxed out. i have the aem fic. the turbo is the turbonetics 60-1 57 trim.
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
what size injectors?
Old Sep 25, 2008
mr jones's Avatar
Re: hp
the injectors are 410 and is the turbo a good choice. its not bb
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
thanks, and that is rated for a 400hp setup. Id be looking to see if the Walbro isnt working harder then it should. I know they are awesome pumps but there are so many variants for a variety of different applications.
Old Sep 25, 2008
mr jones's Avatar
Re: hp
dam 400hp. i guess my tuner made a good selection for my setup like he said he would. thanx for the info bro. was thinking bout bying the p and p head from dezod. what gains can i expect from that with my setup???
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
a good ported&polished head will definetly help that turbo out in a positive way. But just a question....Why would he opt for such a high HP injector on stock internals with a T/C kit?
id be worried about 2 things on your engine:
1. Internals
2. REAL good tune!!!!!!! <<<<MUST!!
Old Sep 25, 2008
mr jones's Avatar
Re: hp
1. Internals
i know before he ordered everything i told him i wanted to max out this setup when i had more money for the internals. i need a aem ems alone with the internals 2. gonna be alot of money. i gotta save up for a lil while.
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
if your spending the time & money on this id like to suggest gasket matching aswell along with the Dezod head, etc... You have Pics of your engine as it is now?
Old Sep 25, 2008
mr jones's Avatar
Re: hp
def planned on the new hg too. i have to take pics of my engine. i will post soon
Old Sep 25, 2008
andyman97's Avatar
Turbo Guru
Re: hp
Yep, you're laziness is due to it being that time of the month for me.
Old Sep 25, 2008
FGCOUPE's Avatar
Re: hp
why is it everyone has to be hostile on this forum? if you didnt like it....dont respond and move on!
Old Sep 25, 2008
mr jones's Avatar
Re: hp
hes a tough guy behind his computer. face to face he wouldnt have nothing to say to me. he would jus look down at the ground like a good like girl. if this topic sux then dont post like fg coupe said. move ur *** on.
Old Sep 25, 2008
andyman97's Avatar
Turbo Guru
Re: hp
Yeah, you're right, I'd be so scared of you. Since your tuner does all your thinking for you, why don't you go back to him with your stupid noobish double posts and questions.
Old Sep 25, 2008
andyman97's Avatar
Turbo Guru
Re: hp
Because morons have driven out the population of intelligent, useful posts.
Old Sep 25, 2008
mr jones's Avatar
Re: hp
this topic sux huh?? y u still posting here. a wise man once told me to never argue with fools. so this gonna be ur last response. and im sure u never had any question bout f\i when u first started. get off my d@@k and off my thread ho. turbo guru flammer. as i hit candyman over the head with a torque wrench.
