K-ECU wire up. Need Help!! (images)
Old Mar 26, 2008
Kore's Avatar
Kore is an unknown quantity at this point
I got a problem. My ECU already has K-pro intalled and wired up (hybrid racing harness), i went to upload the parameters, then it looks like it trying and then i get an error message saying "Upload Failed".
Quick Note: The engine starts right up, but i think is because before i did the swap i had a remote ignition started installed and the imobilizer was by-passed.
I called Hondata tech support and they said that the k-pro circuit board my be damanged, which i was like DAMN IT, i just paid over a grand and **** is not even working!!?? Anyways they said i have to pay more money to have them check it and to replace it is like 300 bucks, 100 to check it. Before i send anything to them i want to make sure my wiring is correct.
Anyone that has done the swap or at least wired up a K-ECU please help!!
Hyrbrid Racing Harness Wire up, by me
1. Yellow Wire - I connected the yellow wire to a white wire on the left side of the passenger side (see above) this is suppose to be KEY ON wire. I was told by some one on the boards that white was kEY ON.
2. BLack - wire was already connected.
3. White Wire - Needed to be connected to the number 8 pin, you can see it on the picture that it is.
4. Blue Wire - The instructions from hybrid said that the RED wire needs to be connected to a 12V Constant. There was no red whire so im assuming they ran out of color wire and used Blue cuz that's the last wire that was left.
I connected that wire to the Cigarett Lighter
Old Mar 27, 2008
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: K-ECU wire up. Need Help!! (images)
the wires u connected has is for the o2 sensor.. nothing to do with the uploading failed... did u try uploading with the key turned to "ON"???.. turn the car on but dont start it... try uploading again.. if not trying dowloading... if u have kpro properly running it will say on the bottom left of the k-manager screen "ignition on".. make sure u see that... do you have more than one usb port on ur laptop??.. try using different ports... if not try upgrading ur k-manager ot the newest version
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Cyborg Ninja
Jun 30, 2021 07:16 PM
em2_k20a
Jun 5, 2015 08:11 AM
Rogelio Rey
May 24, 2015 08:30 PM
MamaBear2015
May 3, 2015 02:17 PM
