K20a3 AC Compressor Wire up
Old Mar 18, 2008
Kore's Avatar
Kore is an unknown quantity at this point
Anyone know where these two wires connect to? The pin wire is off the
the AC Compressor, and the Clip wire is coming off the A3 engine harness.
This is the only thing i'm missing before i fire up my swap.
Old Mar 18, 2008
Kore's Avatar
Re: K20a3 AC Compressor Wire up
Old Mar 25, 2008
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
if you look under your upper radiator supprt.. there should be 3 clips connected to one harness.. 2 clips go to the radiator fan.. and then the 3rd clip should be a single wire cvlip which goes to the a.c compressor
Old Mar 27, 2008
kornsined's Avatar
I had the same problem. Some civics just had a different connector. The a/c has a separate harness so you could just get the one with the proper connections.
Old Mar 27, 2008
depends.. the people i noticed having this problem where the people with 04-05.. on the 01-03 the a/c harness and radiator fans harness where together
Old Mar 27, 2008
kornsined's Avatar
True. Mine was an 04.
cukaracha
30
Jul 26, 2015 12:01 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JUNITO
Jul 9, 2015 08:36 PM
AaronSorenson
Jul 7, 2015 09:40 PM
robbie374
Jul 7, 2015 02:56 AM
