Missing Link
Old Feb 25, 2008
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
Missing Link
My question is do I still need my missing link with my current setup? I have the AEM F/IC piggyback as my tuning device running 8lbs of boost. My car has been torn apart all winter and the AEM unit wasn't installed while the car was running so not sure.
Old Feb 25, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Re: Missing Link
good question...........I didn't need one w/ my emanage since I had a boost sensor installed.........Not sure w/ the AEM but still the same concept.....I believe the AEM should have some sensors of it's own? or possibly even upgrade to an AEM Map sensor for better compatiblity?
Old Feb 25, 2008
andyman97's Avatar
Turbo Guru
Re: Missing Link
Depends on the FIC's ability to read and alter boost signal. You need to be able to read the boost pressure to reference boost tables and you can't do that if you don't have a sensor that reads pressure. That said, there is probably a wiring schematic to wire in a map sensor into the piggyback and have it alter the map signal going into the ecu so it doesn't freak out and go into limp mode when it sees boost.
The stock map can read a little over 10 psi.
Old Feb 25, 2008
speedfoos's Avatar
Re: Missing Link
The F/IC runs a simulated MAP signal to the ECU so it doesn't flip out and takes the true readings off its onboard 2.5 BAR MAP sensor. You still need the stock MAP plugged in, but all the actual boost readings come from onboard the EMS.
So the short answer is no, you don't need a missing link with the F/IC.
Old Feb 25, 2008
andyman97's Avatar
Turbo Guru
Re: Missing Link
Thanks for the confirmation
Old Feb 25, 2008
j182j's Avatar
j182j has a spectacular aura aboutj182j has a spectacular aura aboutj182j has a spectacular aura about
Re: Missing Link
Not to jack your thread but do you needed to mess with the O2 sensors at all then???
Old Feb 25, 2008
speedfoos's Avatar
Re: Missing Link
Nope!
Old Feb 25, 2008
PitchBlack's Avatar
Re: Missing Link
Thanks guys, thats what I was thinking. I already pulled the missing link. I know the AEM unit has a MAP map so I was assuming it would do the missing links job.
Old Feb 25, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Missing Link
Yeah, the built in map is the fooler to the stock ECU. This this day and age of cheap yet semi-useful tuning systems, anyone using a missing link should be beaten.
Old Feb 25, 2008
PitchBlack's Avatar
Re: Missing Link
lol well no beating me. I ditched the TSI fuel system for the AEM and RSX-S injectors.
juicetayne
Sep 30, 2015 11:02 AM
rovafa2002
Sep 28, 2015 06:57 PM
Bruce2
Sep 27, 2015 08:45 PM
