Blown Turbo!
Old Dec 18, 2007
  #31
speedfoos's Avatar
Re: Blown Turbo!
Originally Posted by dezod
Garrett BB turbos come with them from Garrett due to the overly sensitive needs of the CHRA.
That is good to know Paul. It's always nice to have a reason behind things. Completely off-topic here, but do other dezod employees ever use the "dezod" forum user names or is it always you? Hate to be saying, "Yeah Paul, blah blah blah." when it's not Paul.
Old Dec 18, 2007
  #32
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Re: Blown Turbo!
Pauls the only one I get to answer the phone there
Old Dec 18, 2007
  #33
dezod's Avatar
7thgen Power Maker
Re: Blown Turbo!
You luck out severly. I answer the phone about 20% of the time. Enrique does the other 80%. Adam will once in a blue moon if either of us are not there.
I am posting on here 95% of the time. So it's a safe assumption to guess it's me.
Old Dec 19, 2007
  #34
FoSho's Avatar
Re: Blown Turbo!
OK, so I'm still smoke free. Car has been running well, alittle rough at times. The plugs probably have gunk on em again, I'll have to pull em & clean em again. One thing that I am still not happy about it my PCV system. I really hate my design, foo's is better, but none of the systems I have seen work well on relieving the crankcase of pos+ pressure. I was looking at a system alot of muscle car guys use. Weld an nipple on the exhaust w/ a baffle inline.........at idle it will pull alittle but when WOT it has a **** load of vacuum.
I opened the valve on my catch can & got a **** load of water & yellow foamy condensation again! I just left the valve open to drain while I'm at work. I believe it's from the 100% humidity from the winter, possibly hq problems, or my pcv system not able to suck the nasty stuff out!!
Anybody have any good idea's....here are some paint diagrams of my pcv & foo's systems...
foo's
fosho's
Old Dec 19, 2007
  #35
speedfoos's Avatar
Re: Blown Turbo!
Here's the system I will probably go to eventually. It's done by a guy on d-series.org who goes by lkailburn and his post is Here. Check it out.
But if you don't want to check it out, here is the pic and explanation.
Originally Posted by lkailburn
the problem i have with that diagram is that there is no vacuum draw on the crankcase port. the MAIN reason we have a PCV system is neglected. also, any oil vapors that were able to climb up and out would just coat the back of your engine block.. not something i would want to deal with. i know other people just attach a hose and route it to the ground.
but im still going to suggest my method/design which provides some vacuum at all times in a closed catch can system
the reason i add the IM section back in is a slashcut ONLY provides a few in/hg of vacuum under high rpm/high load. which is better than nothing but a filtered, check valved line to the im would provide tons of vacuum everywhere out of boost.
ppl have issues of "dumping all that junk back into the IM".. but inreality, the stock system already does that. PLUS this setup has a catch can, which sole purpose is to CATCH vapors etc. AND in addition to the catch can, a finer inline filter can be added.
a more complex but infinitly more complete setup i believe. and all still being very cheap and resourceful
-Luke
Old Dec 19, 2007
  #36
FoSho's Avatar
Re: Blown Turbo!
Awesome! That is exactly what we need. My pipes & manifold stay clean & my crankcase is always under vacuum, sucking all that gunk out!
Good find, clint! That has the exhaust cuts like the system I was gonna try to mimic. I like the IM thought aswell!
Old Dec 19, 2007
  #37
speedfoos's Avatar
Re: Blown Turbo!
The trick I think is the one-way check valves in Luke's system. Check out his webpage as well. He's a got several nifty ideas and how-tos. I just found it myself.
http://www.lukekailburn.com/
Old Dec 19, 2007
  #38
FoSho's Avatar
Re: Blown Turbo!
HAHA check out DET can.....that is awesome........a silicone hose attched to the block & headphones. That is a ghetto way to listen for detonation!!!
The check valves make that system work great. You have no chance of back pressure or any hiccups going the wrong way!
Old Dec 19, 2007
  #39
ronaldo9's Avatar
Re: Blown Turbo!
I thought Paul sells a PCV system with his kit?
Old Dec 19, 2007
  #40
DriftR's Avatar
DriftR is an unknown quantity at this point
Re: Blown Turbo!
Yeah lkailbrn's looks like it works. Having that check valve btn the TB and the valve cover is the most important. You get the vacuum draw and you won't over pressureize the crankcase under boost conditions.
Old Dec 20, 2007
  #41
FoSho's Avatar
Re: Blown Turbo!
Nope, no pcv system with kit
Would be nice for the money huh? You can buy the optional morso catch can but thats all.
Old Dec 20, 2007
  #42
dezod's Avatar
7thgen Power Maker
Re: Blown Turbo!
Most people just vent the PCV to the atmosphere with a $3 breather filter.
We do offer the Moroso can for less than $100 to cleanly and properly handle the PCV overflow.
Old Dec 20, 2007
  #43
FoSho's Avatar
Re: Blown Turbo!
Here you go............this guy has every possible pcv system on this car, he even performs vacuum tests, & rates each setup. He's got this **** nailed. I learned alot from reading over his post
http://www.honda-tech.com/zerothread/1199935
HondaGuy7
Feb 22, 2016 01:00 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
Mc7602
Sep 17, 2015 02:01 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
