Blown Head Gasket???
Old Sep 10, 2007
  #31
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Re: Blow Head Gasket???
They think it's the valves?
Old Sep 10, 2007
  #32
Niterider2gen's Avatar
Niterider2gen is an unknown quantity at this point
Yeah the dealer told me it was probably the head gasket since coolant was shooting up. So I took it to a cheaper shop and they said its burning coolant and oil and its probably the valves. Their recommendation was to take it somewhere to have the head checked out. I still haven't found a shop willing to do it. Especially with the tsi setup nobody wants to be responsible.
Old Oct 19, 2007
  #33
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
Update........... Well I had my water pump changed and the car seems to be running fine. But my dad told me the car started to overheat yesterday, but i've been driving it all day today in and out of boost, and it been running perfect. Sooooooo........ If anyone have been having the same problem as me check your water pump before taking your head off. But im still going to change my HG because I want to turn up the boost.
P.S.
How unsafe or safe would 10psi with a t3/t4 57trim .60 .63 on a stock engine be
Old Oct 19, 2007
  #34
speedfoos's Avatar
I wouldn't put it on the strip at that psi. I was leary about mine at 9 psi so I backed down to about 8-8.5 psi.
Check and make sure you got all the air out the system after changing out the water pump.
Old Oct 19, 2007
  #35
trurace's Avatar
Yea i've been running at 8.5 for like 2 months now, and I wanted to get it tuned at like 9.5 or 10....... My goal is 200 and I don't really think 8.5psi can make that on a piggyback.
Yea I check already, but im going to double check... just in case
Old Oct 22, 2007
  #36
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
you can get 200whp on a piggyback... which one are you running?
Old Oct 22, 2007
  #37
trurace's Avatar
pcs xfc
Old Oct 23, 2007
  #38
speedfoos's Avatar
You can hit 200 with that piggyback.
Old Oct 23, 2007
  #39
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
if its burning coolant it could be:
cracked head between valves,
headgasket
Old Oct 23, 2007
  #40
trurace's Avatar
Yea I know the XFC can make 200, but im not sure if it will make 200 at 8.5psi. ...... So what do you guys this should I bump the psi up to like 9.5-10 or keep it a 8.5? Im going in for my tune in 2 weeks, so I need to figure this out.
Old Nov 2, 2007
  #41
trurace's Avatar
Alright, well I am in the process of replacing my HG. I took my intercooler off, and there is a layer of water at the bottom of the intercooler? Does this mean I have a bad intercooler?
Old Nov 4, 2007
  #42
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Nope
It means that the coolant/oil went thru the exhaust and pooled in the intercooler,
You have a big job cleaning up ahead of you.
I have some spare heads if you need one.
Good luck
Old Nov 4, 2007
  #43
trurace's Avatar
Ooooooo. Well I already had my head cleaned when I changed my gasket. Does anything else need to be done?
How could coolant/oil have gotten through my exhaust?
Old Nov 5, 2007
  #44
supermex's Avatar
That's what happen when the head gasket goes oil/ coolant get into the combustion chambler and out the exhaust.
You seem to have a severe leak if a pool of coolant is in the intercooler.
Check for a cracks on the head, get a full head overhaul, is not that much and well worth it.
Get ARP studs.
And me personaly will recomend a block guard.
If I was you I'll get the turbo cleaned, all that coolant/ oil shis went right thru the exhaust side of the turbine, clean the 02 sensors as well.
Old Nov 5, 2007
  #45
andyman97's Avatar
Turbo Guru
Coolant will burn in the combustion chamber and blow off a white smoke. If you have coolant pooled up around the radiatior support area, I'm sure its probably what blew out of the overflow tank when you overheated it.
Old Nov 5, 2007
  #46
trurace's Avatar
Im still pretty confused as to what coolant/oil has anything to do with water in my intercooler? Coolant/oil and water a really different. Could water have gotten sucked in turbo and pooled in the intercooler?
I don't know, I will check everything out agian. Im pretty sure my head is good because I had it check when I sent it to get cleaned
Also, after I changed my water pump and timing belt, my car has been running extremely rich. The afr's used to be in the high 13-14 range out of boost and now it is in the rich-10 range. Anyone have any idea of what could be wrong?
Old Nov 5, 2007
  #47
make sure to have the head checked not only for pressure but also for warpage. if you put a warped head back in, it will just blow the gasket again. and if it overheated, it is warped for sure. just make sure before doing everything and having it fail again. maybe your timing is messed up, even by one tooth could change the way it runs. did you get it tuned and with what?
Old Nov 5, 2007
  #48
trurace's Avatar
It was tuned with the xfc. I am trying get it re-tuned, but I just want to make sure everything is ok.
Old Nov 5, 2007
  #49
andyman97's Avatar
Turbo Guru
Water is actually INSIDE the intercooler?
Old Nov 5, 2007
  #50
trurace's Avatar
Yea, I tilted the intercooler sideways and water poured out.
Old Nov 9, 2007
  #51
speedfoos's Avatar
Ouch. Oil+coolant+IC= WTF + really bad.
There is no way that combo of stuff should have gotten into your IC at all. You running an oil and water cooled turbo?
Old Nov 9, 2007
  #52
trurace's Avatar
Lol I don't know where the oil and coolant thing came up, but every keeps mentioning it. There was NO oil and coolant in my intercooler. The was just a pool of WATER.
Old Nov 9, 2007
  #53
speedfoos's Avatar
Still strange. Are you running a catch can? How is your filter routed?
Or a better question. Are you still having the water issue now that it's been 4 days?
Old Nov 9, 2007
  #54
supermex's Avatar
Hmm let's see, your intercooler is conected between the turbo/manifold assembly from the compresion side and the intakes throtle body..
Now there is no way that you have coolant coming from the intakes TB so,
More likely the coolant came from the exhaust into your tubo and out the intercooler.
Sounds like a seal on the turbine is busted and letting compresed air and coolant to the intercooler.
Stiil cooland cooming out of the exhaust is another problem
Do you have a P&P head?
P&P heads can also be a problem if it was bored out too much.
Have you tried to remove a bolt from the block by drilling?
Another theory would be that your engines block ran out of coolant and got so hot that cracked the blocks water jacket
Any way it doesn't sound good.
How is it running right now?
Did you change your HG?
Was the old one bad, did you noticed any damage on the old one when you removed it?
Old Nov 9, 2007
  #55
trurace's Avatar
There isn't any coolant coming out of the exhaust. Coolant or oil really has nothing to do with my problem because there WAS NOT any coolant or oil in my intercooler. There was just a pool of water, not water mix with coolant or water/coolan/oil. Just water, like I could drink it if I wanted to.
I did blow a head gasket, probably due to overheating, but I already changed my gasket and the car is running 100% better. Im not having any overheating problems anymore.
My old head gasket was not that bad, it was just leaking a little
I am running with no filter as of now (I know.... I need to get one). I am guessing water got sucked through my intercooler.
I havn't checked again. I thought maybe someone know what was wrong, but apprantly water in the intercooler is pretty odd lol
P.S. Anyone know a way to route the intake w/o having to do a battery relocation?
Old Nov 9, 2007
  #56
speedfoos's Avatar
Rubber flex pipe from Home Depot and put it right above the tranny in between the fuse box and VTEC solenoid.
Old Nov 9, 2007
  #57
trurace's Avatar
Thanks!!!, do I connect it to the inlet amd filter with a coupler?
Old Nov 10, 2007
  #58
speedfoos's Avatar
You should be able to size it correctly for your filter and turbo inlet. Take some measurements of both and just get stuff to make it work. I've seen folks do this without couplers. I know FoSho is running his this way, and there's a picture of it buried somewhere in my install thread, I just can't find it yet.
Old Nov 10, 2007
  #59
speedfoos's Avatar
Here it is.
Originally Posted by FoSho
....Well I've done the impossible. I have found an intake for the dezod kit without battery relocation!! Oriellys $20 custom build your own intake kit
Check the picture!
Old Nov 10, 2007
  #60
trurace's Avatar
THANKS foos!!!!!!!!! Tried to rep, but I got to spread the love first
