I'm still alive. *UPDATE*
Old Apr 24, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
Currently I'm waiting on Dezod's pistons in order re-build after my blown head gasket.
Already in my possession:
CROWER forged connecting rods
ARP head studs/bolts
a new Honda HG
I'm planning on running like 80% duty on my RSX injectors and stock fuel pump and whatever PSI of boost that happens to be with my current setup. I'm not building for max power - I just wanna be able to beat the **** out of a turbo Civic all day long... it IS my daily driver after all.
Old Apr 24, 2007
skipbarber's Avatar
Re: I'm still alive.
im at 100% duty at a little over 6.5 psi around redline on my rsx-s injectors. are you running the e-mangle?
Old Apr 24, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
By the time you notch the block, rebore the cylinders buy new pumps, bearings, belts, etc..... you may as well punch up the boost. 80% on RSX injectors is about 5 psi, which begs the question, why bother?
Spend the $400 or so to convert to a return system and run 440s... you're gonna put 3k into the motor as it is.
Old Apr 24, 2007
andyman97's Avatar
Turbo Guru
And a good management system like kpro wouldn't be a bad idea either. Even running rsx injectors with a REAL computer on a vtec engine, you'll be at aound 200 whp.
Old Apr 24, 2007
gmcuajo's Avatar
gmcuajo can only hope to improve
Why $400 to convert to a return system? I think for $75 or less plus the regulator...
Old Apr 24, 2007
Jap-Euro Fusion
Regulator, O-ring fittings and plug for the regulator, 15' of stainless hose, 4 hose ends, bulkhead fitting and nuts for the tank cover, pressure gauge = 292.55
Add a walbro at another 95ish and you get 400 bucks.
Old Apr 25, 2007
sl33pyriceboi's Avatar
boilermaker1........ i think ur wayy to smart......
Old Apr 25, 2007
andyman97's Avatar
Turbo Guru
Of course you can go way cheaper if you find a hydraulic shop with brass fittings and rubber hose. I only use "pretty" anodized fittings in the engine bay.
Old Apr 25, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
That's great that you're putting all this work into the performance. I'd love to see the faces on the people you smoke when it's done.
Old Apr 25, 2007
Wel... I am running an E-Manage... and at this point... I really don't feel like running a fuel line all the way to my backseat. I'm having the dealership I used to work for (Honda) perform the rebuild (as I blew the HG).
I am totally done with modding for performance right now... my car is in shambles and I need to fix all the damage.
Boiler... Andy... If either of you feel like explaining exactly how easy it is to convert and how it would take me 1 hour to do... then maybe.
And maybe someone can explain just how so many people run 8 psi... are they overstressing the fuel and running too lean?
*EDIT* and btw... all I'm trying to accomplish here is to make around 200whp SAFELY so I can beat on it and actually enjoy the car.
Old Apr 25, 2007
andyman97's Avatar
Turbo Guru
I told you how...kpro and a good tuner with a return system and rising rate fuel pressure regulator.
Old Apr 25, 2007
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
does anyone make a thicker head gasket for our cars?
Old Apr 25, 2007
Jap-Euro Fusion
They're overdriving the injectors. At 7 psi, I'm running at 94% duty.
You cant run 80% and expect the car to make 200 HP.... the turbo pushes alot more air than a type S does, even with VTEC engaged... the injectors simply cant keep up with that amount of air volume. The S is making power off compression.... and your turbo effective compression is a lot higher than 11:1
Old Apr 25, 2007
andyman97's Avatar
Turbo Guru
You don't need a thicker headgasket than stock.
Old Apr 26, 2007
andyman97's Avatar
Turbo Guru
Everything should hold together fine. The only thing thats going to cause problems is detonation. I wouldn't get them unless I had to change a headgasket.
Old Jun 5, 2007
Re: I'm still alive. *UPDATE*
The car now has everything installed on it. It runs and doesn't blow up... but I don't drive it over 3500 RPMs at the moment - not until it gets tuned.
It makes some scraping sound... like the pistons scraping up and down in the cylinders. I had the rings gapped to the spec given out by WISECO by the Honda dealership I used to work for... so is that just the rings/cylinder walls learning to play nice?
It quiets down after it warms up - but after 100 miles or so should it still be making that sound? Or is that just the sound of aftermarket pistons and it'll always sound like that?
Lastly, the place I'm going to dyno it at says that I should simply put in a Walbro 255L/H pump, bigger injectors and a FPR... is that safe without the return setup?
Anyway... in a week or so I should have some dyno numbers at around 7psi... and shortly after that some new pics.
Old Jun 5, 2007
Jap-Euro Fusion
scraping is not a sound you want to hear.... something isnt right. Either you have a ring with a sharp edge on it, you cracked a ring putting them in or the bore is too tight. Who built the motor?
Old Jun 5, 2007
andyman97's Avatar
Turbo Guru
Scraping? Take the car to a mechanic and see if they can diagnose where its coming from.
You can't run an aftermarket rising rate fpr without a return line.
Old Jun 7, 2007
The Honda dealership I used to work for built the motor. The guy that did the work has been there for 15 something years and is the guy they bring all the rebuilds to.
Now a few days later, the car makes the noise, but ALOT quieter. I really need to get this thing tuned because it's running so rich - it constantly smells like gas.
*UPDATE*
I spoke to the mechanic... he claims a piece of paper coming with the pistons instructed him to give 3/1000in. clearance to compensate for piston expansion. I remember a few sheets of paper in there with a bunch of stuff about clearance and gapping, but didn't read the information at the time.
This would be backed up by the fact that it goes away after it warms up. Also, another mechanic has a turbo'ed B18C1 6th Gen and his makes the same noise, apparently.
Old Jun 10, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Are you hearing piston slap when the engine is warm?
Old Jun 11, 2007
Well... it still makes a noise, but now I've been told be several people that aftermarket pistons just sound different. It's hard to describe over the internet what it is... but most of the people I've talked to have described it as "piston slap."
I won't worry about it until the people at the dyno get a hold of my car and tell me their opinion.
TOOLOWCIVIC
Texas
27
Oct 28, 2003 04:37 PM
