SixSigmaRacing Header for the RSX/DC5
Old Apr 3, 2007
JamesL's Avatar
JamesL is an unknown quantity at this point
I had read around here that any header for the RSX would fit a K20-EM2 swap... People suggestin Comptech, SSR, Buddy Club, etc. Ended up choosing the SSR header for the performance gains and quality.
Then I come to hear that it doesn't work with the front sway bar? Is this one of those, I need a DC5R front sway... Or will the header simply not fit?
Old Apr 3, 2007
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Re: SixSigmaRacing Header for the RSX/DC5
Simply not fit... hits the header itself.
Old Apr 3, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
what headers will fit a k20 in an em2 with a progress front sway?
Old Apr 3, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
what Progress sway? RSX or EM2?
I have heard several times you can run any header with a hotchiks front sway.
Old Apr 4, 2007
I think it's an EM2 front sway, but I'm not sure. Is there a big difference?
Old Apr 5, 2007
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
get a dtr or toda header
Old Apr 5, 2007
considering a EM2 doesnt have the manifold coming off the rear of motor, i would say there is lol. Its a bigger loop in the middle of the sway.
Old Apr 5, 2007
ie:
Old Apr 5, 2007
RAZRBLD's Avatar
TEIN MAN
yeah a Whiteline, Hotchkis, Toda Swaybar will clear i think.
Old Apr 6, 2007
civicvtec1ps's Avatar
Search and Learn
To run DC5R, You would need JDM Front LCA'S, axles.
I am assuming you will run either SI or RSX axles with Si sub frames.
Toda, Whiteline will clear.
Here's Toda front sway I had.
SSR > Any other Aftermarket race header out there.
Wish I could afford one.
Old Apr 6, 2007
RAZRBLD's Avatar
TEIN MAN
i bought one. I love it.
Old Apr 6, 2007
HondaLuver's Avatar
Its a celebration bitches!
my stock ex would have fit but the k24 was too high, didn't have a front sway for a while because every one said it would hit.
when i put my k20 in, i put my progress front in. works fine...
Old Apr 6, 2007
RAZRBLD's Avatar
TEIN MAN
So Progress will clear as well... great good news
Old Apr 7, 2007
word. well, i'm k-swapped so i must definitely have a DC5 one. I didn't even think about it.
Old Apr 9, 2007
RAZRBLD's Avatar
TEIN MAN
DC5 one wont fit a race header.
Old Apr 11, 2007
JamesL's Avatar
Yes, I will be running Si axles/sub frame. I was under the impression that you did not need the JDM front LCAs to run the JDM front sway...
Old Apr 13, 2007
RAZRBLD's Avatar
TEIN MAN
I think in order to runa dc5r sway bar you need JDM front LCA's. Ask the guys on clubrsx.
Old Apr 13, 2007
eye_see_you's Avatar
let the devil out
SSR makes the headers for the K20 swaps and it will fit with the EM2 Sway from what i have read, the BC is the only other comparable header for the cost
Old Apr 18, 2007
JamesL's Avatar
Thanks for the replies fellas....
Old Apr 18, 2007
HondaLuver's Avatar
yea, you needs jdm LCA for a jdm sway
Old Apr 19, 2007
JamesL's Avatar
So Progress/Toda/Whiteline front swaybars will fit...
For the DC5 I assume?
Old Dec 29, 2007
k20EX's Avatar
k20EX is an unknown quantity at this point
Old thread, but.....I need to know if anyone is running the STRUP RH, and if so, with what front sway bar?? BTW, I am getting the STRUP RH for a good deal, so Im not interested about which RH is best, just which sway bar will clear a STRUP RH.....and from what I have heard, the STRUP and DCRH are very similar, so let me know what sways (brand and DC5/DC5R/EM2) you are running with the DCRH as well.....THANKS!!!
Old Dec 29, 2007
RAZRBLD's Avatar
TEIN MAN
No sway bar currently... Im running a Hytech header though.
Old Jan 22, 2008
k20EX's Avatar
OK, soooo...could people please list the raceheader/front sway combo that they are running or KNOW works (chasis and brand)...thanks
Old May 6, 2008
k20EX's Avatar
Well, I will be recieving my Toda RH and Toda sway bar soon.....I hope this fits correctly. Luckily from what people are saying here, the Today sway clears most of these headers, and hopefully that includes their own on this application. New custom catback on the way as well!!
Old May 16, 2008
RAZRBLD's Avatar
TEIN MAN
HYTECH HEADER
Old Jul 11, 2008
k20EX's Avatar
RAZRBLD....could you take any pics of where the header connects to the custom piping? I am trying to figure out if I can fit a small hi flow cat in their as a removal piece to swap in a test pipe section when I need to. Its hard to predict what kind of room I will have, but with your piping it would help a lot to see better pictures of the how the header back piping will connect. Thanks.
Old Jul 12, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
ill snap some pics for you tomorrow. ill be putting on a rear sway so ill snap em while im down there
Old Jul 12, 2008
k20EX's Avatar
OK, thanks Phil....Ive alredy ordered my RH, resonator and muffler...but am trying to fit a removable cat in there somewhere after the RH....the RSX guys are doing it, but I need to see what kind of room Im working with here before I try to piece that together. Im interested in the clearance area on the underbody of the car where the RH and exhaust meet, and the area before the resonator. Thanks!
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
