FUEL RAIL,which one to modify
Old Mar 24, 2007
Jwasiliw's Avatar
Jwasiliw is an unknown quantity at this point
Hey Everyone,
I understand that nobody manufacturers a direct fit fuel rail for our D17 engines.
Which fuel rail should I purchase and is the easiest to modify (off of what vehicle/engine)
Old Mar 25, 2007
C2i0v0i1C's Avatar
SuperMODrizd
Re: FUEL RAIL,which one to modify
the one on the car now?
Old Mar 25, 2007
andyman97's Avatar
Turbo Guru
You don't have to modify the stock rail. All you need is a t fitting in the stock feed. One end will go to the rail, the other will go to the fuel pressure regulator, then run your return line from the regulator back to the tank.
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
Valkman
Aug 13, 2015 04:19 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
