Fuel Pressure Setting On A Turbo Set Up?
Old Mar 19, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
Question Fuel Pressure Setting On A Turbo Set Up?
MY QUESTION IS THIS ON A TURBO SET SET UP ,WHAT SHOULD BE THE FUEL PRESSURE SET AT? IF NO ONE HAS FOLLOWED MY TURBO MOD THREAD. CK IT OUT AND LET ME KNOW WHAT A REC. FUEL PRESSURE WOULD BE .I HAVE HEARD FROM 42-50 PSI. I GUESS IT WILL BE DETERMANED AT THE DYNO RUN AND TUNE . BUT NEED A GOOD SAFE AREA TO RUN IN. IM RUNNING A SLP FUEL RETURN SET UP WITH A WALBRO PUMP AND FPR. LOOKING FOR SOME IDEAS FROM THE BOOSTED MEMBERS OUT THERE . THANK YOU
Old Mar 19, 2007
dezod's Avatar
7thgen Power Maker
Most OEM fuel systems are 3 BAR. Example is the tC 42-47 PSI
Old Mar 19, 2007
tfnaaf's Avatar
BLDNPSI Mod
im running 44psi on a return system with walbro in tank with the vacuum refernce NOT hooked up. Im running constant pressure and tuned to that.
Old Mar 22, 2007
andyman97's Avatar
Turbo Guru
Re: Fuel Pressure Setting On A Turbo Set Up?
Mine's set around 42-45 psi. Doesn't matter what you set it at really. The reason for the adjustment capability is to be able to get enough fuel on the top end without maxing and destroying an injector.
Old Mar 22, 2007
dezod's Avatar
7thgen Power Maker
Fuel pressure does matter because it depends on the flow rate of the injector your using. Example is a 1000cc injector that may be rated THAT CC, AT 4 BAR ~ 58 PSI. If you need all 1000cc of that injector's pulse width then you need to run a consistent 4 BAR of FP or so.
What your referring to is a common tuner practice to help the fuel atomize better and squeeze some more out of the injectors.
Old Mar 22, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Fuel pressure matters if you care about the life of your injectors... if a injector cals for a 48psi fuel pressure, and you run higher you can put a lot of excess strain on the injector and ruin it. And if you under pressure it, you will just end up maxing the injectors out quicker which causes them to work harder and can kill the life of them. do a little research before you post that.
Stock regulator runs at 40psi i believe, so if i were you i would sit with a happy medium of 45 or 46 and get it tuned!
Old Mar 22, 2007
andyman97's Avatar
Turbo Guru
For someone who doesn't know what to set fuel pressure at, it doesn't really matter. If he doesn't understand these concepts, he obviously isn't going to be running an extremely high hp setup right out of the box. When you talk flow rate, you're talking max flow rate, not partial throttle flow rate. If he is running rsx injectors, he could run 35 psi for fuel pressure and be fine. If its a rising rate regulator, at, say 10 psi, he should still have plenty of fuel, as his flow rate is increasing with every psi of boost.
Old Mar 22, 2007
personally mine is set for 48 cause thats what my injectors said when i got them out the box!
Old Mar 22, 2007
dezod's Avatar
7thgen Power Maker
You must not have read or misunderstood my post 100%.
Or you misquoted.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
cmart1209
May 29, 2015 04:52 AM
mrcell24
May 19, 2015 10:02 AM
MooCoW
Nov 15, 2001 10:58 AM
