K20 NA Swap, with Turbo Lag?
Old Mar 13, 2007
feet_'s Avatar
feet_ is an unknown quantity at this point
Well it feels like turbo lag (0 RPM - 3000RPM) when i have the throttle 1/2 to WOT.
It just bogs then power kicks in, in the upper ranges of the tach.(Before VEEEEEEE TAKKKKK)
In every gear. More noticable in 1rst,2nd,and 3rd Gear
Sometimes it bogs throughout the rev range, esp. after a heavy rain, or I power wash the car
Anyone else have this problem?
K20 type s swap into a 4dr 2k1 civic.
Stock motor w/ JDM type R ECU
Could it be?
1. Coil Packs going?
2. Water contamination somewhere?
3. Fuel not being delivered fast enough?
4. plugged Fuel Filter?
Old Mar 13, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
It just bogs then power kicks in, in the upper ranges of the tach.(Before Vtech)
What is "Vtech"?
Old Mar 13, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
You have everything wired correctly? and why you using a type R ecu on a type s motor?
Old Mar 13, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
^ i was wondering about the ecu as well... why not a type s ecu, i mean it is a stock motor. and doesn't the jdm ecu/motor have different vtec points from the usdm type s motor?
Old Mar 13, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
correctamundo..... well at least i thought correctamundo
Old Mar 13, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
I'm thinkin its got something to do with a timing/injector pulse difference. The Type R has bigger cams in it, and you're probably bogging it down with too much gas. Get an A2 ECU, flash it or Kpro it.
Old Mar 13, 2007
feet_'s Avatar
PRB i think the ecu is
its to defeat the key imobilizer
Old Mar 13, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ You should be ok to run the JDM ECU, if you say this only happens after you wash the car or if it is raining, you might want to check any exposed wiring that can come in contact with water. Might just be bad grounding causing the car to drive rough. Double check all the wiring.. maybe you just need to do a tune-up.
Old Mar 13, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
mmmmmmmmm turbo lag in a naturally aspirated car mmmmmmmmm
Sounds good, kind of like a good doughnut!!!
Know what I mean?
Old Mar 13, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
u dont deserve that car.......or for that matter..u dont deserve that swap.....
Old Mar 13, 2007
Nameless's Avatar
TURTLEonK
Why not exactly?
Old Mar 13, 2007
lxcivic2k1's Avatar
because he is having a problem with a modified car?
If it only happens after ran/wash then its probably wires or something that is exposed to water. If it runs fine during dry then its probably not the ECU.
Old Mar 13, 2007
03logic's Avatar
03logic is an unknown quantity at this point
+1
check your wires. my dad had the same problem with his crx, was just wires.
Old Mar 13, 2007
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Water and electricity doesnt mix buddy. Check the wires!!
Old Mar 13, 2007
D5cIvIc's Avatar
what a stupid post
Old Mar 13, 2007
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
^^^^^^^totatly agree with u.
Old Mar 13, 2007
tougEMII's Avatar
sorry if imma spend 8K for a swap..id do it right the first time and research instead of messing up and using stupid terms like turbo lag on a na or vtech. might be acting stupid but its annoying when i see that. to be honest and an ******* even more id say u were a noob with a nice job and someone else cud benefit from that motor besides u. i thought it was amazingly stupid when i read this title. well anyways so no one else has a BF, i apologize for my *******ness. dont take it up the ***.
Old Mar 13, 2007
mikenam's Avatar
mikenam is an unknown quantity at this point
"Well it feels like turbo lag"
its a motor not a like blood donation or an organ.
calm down mang.
Old Mar 13, 2007
tougEMII's Avatar
i am calm. its not like im screaming and yelling and smashing my keyboard....cheesecake. ok imma go canyon......peaaaaaaace
Old Mar 13, 2007
D5cIvIc's Avatar
well he said it was LIKE turbo lag, since that was basically what he was comparing it to. Using VtecH could have been a mistake. There's is nothing in his thread that said he did something wrong. Little problems like this occur when diong a swap. No one here has done a swap and ended up with no problems what so ever the first time around. there is always little things you got to work out.
Also whats up with the BF statement? and cheescake? where the hell did you grow up to talk like that?
ahh...watevers..i can't expect much from you anyways. You're 18 and probably just got out of high school and still within that i'm too cool stage. i'm out
Old Mar 13, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
the type r ecu does not have the immobilizer BUT it does have a fuel cut off if the harness is ont grounded properly or kpro isnt attached to it to over ride said cut off, might be your issue might not just 2 pennies that i had laying around.
Old Mar 14, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Could it be?
Old Mar 14, 2007
tougEMII's Avatar
calm down mr 22yrs old...sheesh....i dont care what u expect from me..i dont think im cool at all..im a nerd and im drive a lot. if u wanna settle something...call me up and we'll run..drag...or canyon =d im trying to forget all this and i apologized and all u do is attack me more..learn a crappy sense of humor so u can just forget about it. i already admitted my mistakes..so basically what im telling u is..f**k off.. so basically shut ur mouth and leave an 18 yr old alone. because ur 22 and u should be responisble*sarcastic*. stop picking fights. damn im tired...malibu canyon cruise....
edit: nvm u live in new york...i dont care about ur comments so say w.e
Old Mar 14, 2007
Nameless's Avatar
TURTLEonK
okay ladies, lets just drop it... thank-you.
Old Mar 14, 2007
sl33pyriceboi's Avatar
^ man.......that was awesome......totally made my day.......hahah
nice tougEMII +1 for you bro.
at least tougEMII is mature about it....unlike alot of ppl on this forum
Old Mar 14, 2007
D5cIvIc's Avatar
i'm just going to let it be. Also..i don't think you would want to drag. Canyon...I'll give you that one though
Old Mar 14, 2007
D5cIvIc's Avatar
yeah realll mature...i can tell
Old Mar 14, 2007
atl01's Avatar
have u fixed your car yet. I would deff change the ecu to the type s one.
Old Mar 14, 2007
feet_'s Avatar
Good call.
Actually Battlendless did the swap (their sub contract garage I garage )
Its the 2001 Black 4dr, I bought it off your customer Danial A.
Old Mar 14, 2007
feet_'s Avatar
thx
btw im 32
