Turbo not going into boost! Help!
Old Mar 7, 2007
kronickz's Avatar
kronickz is an unknown quantity at this point
Hey, my turbo isn't going into boost and I don't know why!!! It has a vaccuum read on the boost gauge but won't go into boost. I can hear the turbo spooling but don't feel anything and my blow off valve isn't doing anything. I checked all piping and hoses and everything is in tact and I don't think that my wastegate is stuck open because i can still move it and it still retracts. HELP ME PLEASE! Also, if it just so happens that my wastegate is stuck open, how do i fix that? And, I need to clarify how I ran my hoses. I have a hose running from the wastegate actuator to the nipple on my turbo since I don't want to adjust stock settings, the b.o.v. and boost gauge are hooked up the the vaccuum line. If I have something wrong then let me know. Everything has been working until these last couple of days. Thanks.
Old Mar 7, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
if its an adjustable arm, then make sure that the flapper is shut (arm not too long). otherwise, you're gonna have to keep looking for a boost leak, and I wouldnt hammer the gas to find out, if the cold side is leaking its free to overspeed since there's no boost resisting and the WG isnt opening without the boost to trigger it.
Old Mar 7, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Are you not going into boost while driving or while standing still?
May be you just need to get your car upto speed and then see if it boosts.
Old Mar 7, 2007
civ_nate's Avatar
civ_nate is an unknown quantity at this point
i assume by saying you dont feel anything he is doing both driving and standing still, your gonna ahve to find a leak in ur charge piping dude, or check ur wastegate again, cant really be too much if you here spool
Old Mar 8, 2007
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
check your blowoff valve it could be stuck open. i had that happen to me once. also double check your pipings again, it may look like its connected so try pulling on the connections to see if its on tight.
Old Mar 8, 2007
kronickz's Avatar
alright thanks for all the help, i'm going to check again today but keep em comin
bowie
Jan 21, 2018 09:29 PM
HondaGuy7
Feb 22, 2016 01:00 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
