emanage for 04 ex coupe settings!!help!!!!
Old Jan 26, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
gime all da info guys......i searched and found... tryed the suppose correct settinge at they didnt work.. 4-8-e with jumpers how madhweel showed..need help asap..
Old Jan 26, 2007
ronaldo9's Avatar
If 4-8-E doesn't work try 4-8-C but I'm using 4-8-E on my 03 EX and it works fine. Is you're wiring correct or did you use the PNP harness?
Old Jan 26, 2007
pnp harness.. does nething hav eto eb changed on that ahrness?
Old Jan 26, 2007
ronaldo9's Avatar
No, it should be a direct PNP unless the wiring in the harness is wrong but I doubt that. Also andyman has a nice write up on emanage settings to use as well did you read that?
Old Jan 26, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Now why would anyone do that?
Read the 2 huge threads in the FAQ.
tock172
Jun 22, 2015 09:37 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
cmart1209
May 29, 2015 04:52 AM
jdawgzcivic
May 20, 2015 08:14 PM
SoyerOner
May 11, 2015 09:46 PM
